[Problem] Motherboard's Audio
Im having an audio problem right now.
I have a Gigabyte 78LMT-USB3 motherboard. Windows 8.1.
The problem is that I have no mic boost options in my audio settings for my usb nor my 3.5 jack microphones as show in the picture.
I have installed the the drivers that came with the motherboard but there was also no option for mic boost so I went and got the drivers from the gigabyte website and VIA website as well.
Neither gave me the option for mic boost.
This is very irritating as when I am in chats, my friends cannot hear me.
I have also included my DxDiag. (Click Here)
do you use the front audio ports of your case? did you allready try the back ports? on the mobo it self?
My previous case had 2 front panel audio connectors AC97 and HD audio, which one you pluged in, i needed to set that in the bios. otherwise the front ports did not work correctly.
