Hello guys i have a pretty annoying problem to do with the driver messing with me and what has happened is the text has being pixelated and the bottom bar is turned from a light brown grayish color to a dark brown turd like color witch i simply don't know how to fix it and its just a pain the fix is probably simple but i don't know how to fix this. This may be important but im using HDMI.
http://i.imgur.com/MdiUxvN.png this is what it looks like.
Hmm... Looking at the provided screenshot i can't see anything wrong with it. It must be an issue with the connection between your monitor and your gpu, the gpu seems to be rendering everything fine.
You could try to reinstall the drivers or test with a different Monitor or eventually HDMI port.
I did and it looked good but why wont it work properly on a monitor with HDMI??? MY main has VGA and HDMI so i don't know what to do????
R9 290 Tri-x from sapphire and it seems i fixed the problem after 5 hours of playing around with settings.
