I got the 2tb ssd, and the power supply (600w sff) and the gtx 1080 already, it’s just the CASE ram MBOB and cpu. Was looking at the N case and the Noctua L12 cooler or this other one.
And currently, I own the AOURS Master z590 but don’t know if i’m going to return it yet or not.
Even with these prices the 12 core zen is still tempting.
I can squeeze one aic in with the N-atx case, right behind the 2 slot gpu.
But not matter what I can’t spend more than say $550 ish for cpu and mobo.
The 5700 g honestly looks good because you can pass through the apu for virtualization. But i’m hoping the 11700k prices tank tbh
What MazeFrame said - Fiber Channel is a completely different interface from Ethernet. Most/many surplus 10G Ethernet cards will come with an SFP cage which is what you see, which takes an SFP transceiver that sends/receives over some physical interface. Most are fiber, but you can also get RJ45 which is your ‘standard’ copper Ethernet cable which is what I was suggesting.
Prices include shipping, taxes, rebates, and discounts
Total
$1642.46
Generated by PCPartPicker 2022-10-07 16:08 EDT-0400
@BroadBandElf said, “I got the two Gigabyte SSD, the power supply (600w stuff), and the gtx 1080 already; it’s just the case, ram, Motherboard, and CPU I need. I was looking at the N case and the Noctua L12 cooler.”
I would advise against the N Case; it looks like a good idea, but in my opinion, it limits any expansion, and the N Case is costly compared to other ATX motherboard cases. I also advise against an SFF type of power supply. I don’t think an SFF-type power supply can support an ATX motherboard, or it would limit any expansion like the N Case. Please watch posted video before you purchase the N Case.
@BroadBandElf said, “And currently, I own the AOURS Master z590, but I don’t know if I’m going to return it yet or not.
Even with these prices, the 12 core zen is still tempting.”
Since you already have an Intel motherboard, I would build an Intel system and forget about AMD.
