Hey @tricsta, I believe I am getting similar issue as you, although mine might be more pervasive. Hopefully we can help each other figure this out.
Differences for me are that I am running a 5975wx, have two of the M.2 cards with 5 980 PROs, 2 P5800X Optane drives via a PCIe to U.2 expansion board, and a 6900XT graphics card.
I have been attempting to diagnose the issue by swapping in and out the hardware I have. When I have only the graphics card installed in slot 1 with no others, I don’t get any errors. Card runs to full utilization according to radeontop in games.
When I start moving the graphics card in solo down PCIe slots, the errors below start to appear to a small amount and quite infrequently.
When all hardware is installed, every ~6 seconds I get some grouping of messages similar to what you have. In my case below is what I am getting.
[ 4405.354132] {1617}[Hardware Error]: Hardware error from APEI Generic Hardware Error Source: 512
[ 4405.354135] {1617}[Hardware Error]: It has been corrected by h/w and requires no further action
[ 4405.354136] {1617}[Hardware Error]: event severity: corrected
[ 4405.354137] {1617}[Hardware Error]: Error 0, type: corrected
[ 4405.354138] {1617}[Hardware Error]: section_type: PCIe error
[ 4405.354139] {1617}[Hardware Error]: port_type: 4, root port
[ 4405.354139] {1617}[Hardware Error]: version: 0.2
[ 4405.354140] {1617}[Hardware Error]: command: 0x0407, status: 0x0010
[ 4405.354140] {1617}[Hardware Error]: device_id: 0000:60:01.1
[ 4405.354141] {1617}[Hardware Error]: slot: 0
[ 4405.354142] {1617}[Hardware Error]: secondary_bus: 0x61
[ 4405.354142] {1617}[Hardware Error]: vendor_id: 0x1022, device_id: 0x1483
[ 4405.354143] {1617}[Hardware Error]: class_code: 060400
[ 4405.354143] {1617}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0012
[ 4405.354144] {1617}[Hardware Error]: Error 1, type: corrected
[ 4405.354144] {1617}[Hardware Error]: section_type: PCIe error
[ 4405.354145] {1617}[Hardware Error]: port_type: 4, root port
[ 4405.354145] {1617}[Hardware Error]: version: 0.2
[ 4405.354145] {1617}[Hardware Error]: command: 0x0407, status: 0x0010
[ 4405.354146] {1617}[Hardware Error]: device_id: 0000:60:01.1
[ 4405.354147] {1617}[Hardware Error]: slot: 0
[ 4405.354147] {1617}[Hardware Error]: secondary_bus: 0x61
[ 4405.354147] {1617}[Hardware Error]: vendor_id: 0x1022, device_id: 0x1483
[ 4405.354148] {1617}[Hardware Error]: class_code: 060400
[ 4405.354148] {1617}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0012
[ 4405.354149] {1617}[Hardware Error]: Error 2, type: corrected
[ 4405.354149] {1617}[Hardware Error]: section_type: PCIe error
[ 4405.354150] {1617}[Hardware Error]: port_type: 4, root port
[ 4405.354150] {1617}[Hardware Error]: version: 0.2
[ 4405.354151] {1617}[Hardware Error]: command: 0x0407, status: 0x0010
[ 4405.354151] {1617}[Hardware Error]: device_id: 0000:60:01.1
[ 4405.354152] {1617}[Hardware Error]: slot: 0
[ 4405.354152] {1617}[Hardware Error]: secondary_bus: 0x61
[ 4405.354153] {1617}[Hardware Error]: vendor_id: 0x1022, device_id: 0x1483
[ 4405.354153] {1617}[Hardware Error]: class_code: 060400
[ 4405.354153] {1617}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0012
[ 4405.354154] {1617}[Hardware Error]: Error 3, type: corrected
[ 4405.354154] {1617}[Hardware Error]: section_type: PCIe error
[ 4405.354155] {1617}[Hardware Error]: port_type: 4, root port
[ 4405.354155] {1617}[Hardware Error]: version: 0.2
[ 4405.354155] {1617}[Hardware Error]: command: 0x0407, status: 0x0010
[ 4405.354156] {1617}[Hardware Error]: device_id: 0000:60:01.1
[ 4405.354156] {1617}[Hardware Error]: slot: 0
[ 4405.354157] {1617}[Hardware Error]: secondary_bus: 0x61
[ 4405.354157] {1617}[Hardware Error]: vendor_id: 0x1022, device_id: 0x1483
[ 4405.354157] {1617}[Hardware Error]: class_code: 060400
[ 4405.354158] {1617}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0012
[ 4405.354158] {1617}[Hardware Error]: Error 4, type: corrected
[ 4405.354159] {1617}[Hardware Error]: section_type: PCIe error
[ 4405.354159] {1617}[Hardware Error]: port_type: 4, root port
[ 4405.354159] {1617}[Hardware Error]: version: 0.2
[ 4405.354160] {1617}[Hardware Error]: command: 0x0407, status: 0x0010
[ 4405.354160] {1617}[Hardware Error]: device_id: 0000:60:01.1
[ 4405.354160] {1617}[Hardware Error]: slot: 0
[ 4405.354161] {1617}[Hardware Error]: secondary_bus: 0x61
[ 4405.354161] {1617}[Hardware Error]: vendor_id: 0x1022, device_id: 0x1483
[ 4405.354162] {1617}[Hardware Error]: class_code: 060400
[ 4405.354162] {1617}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0012
[ 4405.354162] {1617}[Hardware Error]: Error 5, type: corrected
[ 4405.354163] {1617}[Hardware Error]: section_type: PCIe error
[ 4405.354163] {1617}[Hardware Error]: port_type: 4, root port
[ 4405.354163] {1617}[Hardware Error]: version: 0.2
[ 4405.354164] {1617}[Hardware Error]: command: 0x0407, status: 0x0010
[ 4405.354164] {1617}[Hardware Error]: device_id: 0000:60:01.1
[ 4405.354165] {1617}[Hardware Error]: slot: 0
[ 4405.354165] {1617}[Hardware Error]: secondary_bus: 0x61
[ 4405.354166] {1617}[Hardware Error]: vendor_id: 0x1022, device_id: 0x1483
[ 4405.354166] {1617}[Hardware Error]: class_code: 060400
[ 4405.354166] {1617}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0012
[ 4405.354167] {1617}[Hardware Error]: Error 6, type: corrected
[ 4405.354167] {1617}[Hardware Error]: section_type: PCIe error
[ 4405.354168] {1617}[Hardware Error]: port_type: 4, root port
[ 4405.354168] {1617}[Hardware Error]: version: 0.2
[ 4405.354168] {1617}[Hardware Error]: command: 0x0407, status: 0x0010
[ 4405.354169] {1617}[Hardware Error]: device_id: 0000:60:01.1
[ 4405.354169] {1617}[Hardware Error]: slot: 0
[ 4405.354170] {1617}[Hardware Error]: secondary_bus: 0x61
[ 4405.354170] {1617}[Hardware Error]: vendor_id: 0x1022, device_id: 0x1483
[ 4405.354170] {1617}[Hardware Error]: class_code: 060400
[ 4405.354171] {1617}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0012
[ 4405.354171] {1617}[Hardware Error]: Error 7, type: corrected
[ 4405.354172] {1617}[Hardware Error]: section_type: PCIe error
[ 4405.354172] {1617}[Hardware Error]: port_type: 4, root port
[ 4405.354172] {1617}[Hardware Error]: version: 0.2
[ 4405.354173] {1617}[Hardware Error]: command: 0x0407, status: 0x0010
[ 4405.354173] {1617}[Hardware Error]: device_id: 0000:60:01.1
[ 4405.354173] {1617}[Hardware Error]: slot: 0
[ 4405.354174] {1617}[Hardware Error]: secondary_bus: 0x61
[ 4405.354174] {1617}[Hardware Error]: vendor_id: 0x1022, device_id: 0x1483
[ 4405.354174] {1617}[Hardware Error]: class_code: 060400
[ 4405.354175] {1617}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0012
[ 4405.354175] {1617}[Hardware Error]: Error 8, type: corrected
[ 4405.354176] {1617}[Hardware Error]: section_type: PCIe error
[ 4405.354176] {1617}[Hardware Error]: port_type: 4, root port
[ 4405.354176] {1617}[Hardware Error]: version: 0.2
[ 4405.354177] {1617}[Hardware Error]: command: 0x0407, status: 0x0010
[ 4405.354177] {1617}[Hardware Error]: device_id: 0000:60:01.1
[ 4405.354178] {1617}[Hardware Error]: slot: 0
[ 4405.354178] {1617}[Hardware Error]: secondary_bus: 0x61
[ 4405.354178] {1617}[Hardware Error]: vendor_id: 0x1022, device_id: 0x1483
[ 4405.354179] {1617}[Hardware Error]: class_code: 060400
[ 4405.354179] {1617}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0012
[ 4405.354180] {1617}[Hardware Error]: Error 9, type: corrected
[ 4405.354180] {1617}[Hardware Error]: section_type: PCIe error
[ 4405.354181] {1617}[Hardware Error]: port_type: 4, root port
[ 4405.354181] {1617}[Hardware Error]: version: 0.2
[ 4405.354181] {1617}[Hardware Error]: command: 0x0407, status: 0x0010
[ 4405.354182] {1617}[Hardware Error]: device_id: 0000:60:01.1
[ 4405.354182] {1617}[Hardware Error]: slot: 0
[ 4405.354183] {1617}[Hardware Error]: secondary_bus: 0x61
[ 4405.354183] {1617}[Hardware Error]: vendor_id: 0x1022, device_id: 0x1483
[ 4405.354183] {1617}[Hardware Error]: class_code: 060400
[ 4405.354184] {1617}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0012
[ 4405.354184] {1617}[Hardware Error]: Error 10, type: corrected
[ 4405.354185] {1617}[Hardware Error]: section_type: PCIe error
[ 4405.354185] {1617}[Hardware Error]: port_type: 4, root port
[ 4405.354185] {1617}[Hardware Error]: version: 0.2
[ 4405.354186] {1617}[Hardware Error]: command: 0x0407, status: 0x0010
[ 4405.354186] {1617}[Hardware Error]: device_id: 0000:60:01.1
[ 4405.354187] {1617}[Hardware Error]: slot: 0
[ 4405.354187] {1617}[Hardware Error]: secondary_bus: 0x61
[ 4405.354187] {1617}[Hardware Error]: vendor_id: 0x1022, device_id: 0x1483
[ 4405.354188] {1617}[Hardware Error]: class_code: 060400
[ 4405.354188] {1617}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0012
[ 4405.354188] {1617}[Hardware Error]: Error 11, type: corrected
[ 4405.354189] {1617}[Hardware Error]: section_type: PCIe error
[ 4405.354189] {1617}[Hardware Error]: port_type: 4, root port
[ 4405.354190] {1617}[Hardware Error]: version: 0.2
[ 4405.354190] {1617}[Hardware Error]: command: 0x0407, status: 0x0010
[ 4405.354190] {1617}[Hardware Error]: device_id: 0000:60:01.1
[ 4405.354191] {1617}[Hardware Error]: slot: 0
[ 4405.354191] {1617}[Hardware Error]: secondary_bus: 0x61
[ 4405.354191] {1617}[Hardware Error]: vendor_id: 0x1022, device_id: 0x1483
[ 4405.354192] {1617}[Hardware Error]: class_code: 060400
[ 4405.354192] {1617}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0012
[ 4405.354193] {1617}[Hardware Error]: Error 12, type: corrected
[ 4405.354193] {1617}[Hardware Error]: section_type: PCIe error
[ 4405.354193] {1617}[Hardware Error]: port_type: 4, root port
[ 4405.354194] {1617}[Hardware Error]: version: 0.2
[ 4405.354194] {1617}[Hardware Error]: command: 0x0407, status: 0x0010
[ 4405.354195] {1617}[Hardware Error]: device_id: 0000:60:01.1
[ 4405.354195] {1617}[Hardware Error]: slot: 0
[ 4405.354195] {1617}[Hardware Error]: secondary_bus: 0x61
[ 4405.354196] {1617}[Hardware Error]: vendor_id: 0x1022, device_id: 0x1483
[ 4405.354196] {1617}[Hardware Error]: class_code: 060400
[ 4405.354197] {1617}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0012
[ 4405.354197] {1617}[Hardware Error]: Error 13, type: corrected
[ 4405.354198] {1617}[Hardware Error]: section_type: PCIe error
[ 4405.354198] {1617}[Hardware Error]: port_type: 4, root port
[ 4405.354198] {1617}[Hardware Error]: version: 0.2
[ 4405.354199] {1617}[Hardware Error]: command: 0x0407, status: 0x0010
[ 4405.354199] {1617}[Hardware Error]: device_id: 0000:60:01.1
[ 4405.354199] {1617}[Hardware Error]: slot: 0
[ 4405.354200] {1617}[Hardware Error]: secondary_bus: 0x61
[ 4405.354201] {1617}[Hardware Error]: vendor_id: 0x1022, device_id: 0x1483
[ 4405.354201] {1617}[Hardware Error]: class_code: 060400
[ 4405.354202] {1617}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0012
[ 4405.354210] {1618}[Hardware Error]: Hardware error from APEI Generic Hardware Error Source: 514
[ 4405.354211] {1618}[Hardware Error]: It has been corrected by h/w and requires no further action
[ 4405.354211] {1618}[Hardware Error]: event severity: corrected
[ 4405.354212] {1618}[Hardware Error]: Error 0, type: corrected
[ 4405.354212] {1618}[Hardware Error]: section_type: PCIe error
[ 4405.354212] {1618}[Hardware Error]: port_type: 0, PCIe end point
[ 4405.354213] {1618}[Hardware Error]: version: 0.2
[ 4405.354213] {1618}[Hardware Error]: command: 0x0406, status: 0x0010
[ 4405.354214] {1618}[Hardware Error]: device_id: 0000:61:00.0
[ 4405.354214] {1618}[Hardware Error]: slot: 0
[ 4405.354214] {1618}[Hardware Error]: secondary_bus: 0x00
[ 4405.354215] {1618}[Hardware Error]: vendor_id: 0x8086, device_id: 0x4140
[ 4405.354215] {1618}[Hardware Error]: class_code: 010802
[ 4405.354216] {1618}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0000
[ 4405.354216] {1618}[Hardware Error]: Error 1, type: corrected
[ 4405.354217] {1618}[Hardware Error]: section_type: PCIe error
[ 4405.354217] {1618}[Hardware Error]: port_type: 0, PCIe end point
[ 4405.354217] {1618}[Hardware Error]: version: 0.2
[ 4405.354218] {1618}[Hardware Error]: command: 0x0406, status: 0x0010
[ 4405.354218] {1618}[Hardware Error]: device_id: 0000:61:00.0
[ 4405.354218] {1618}[Hardware Error]: slot: 0
[ 4405.354219] {1618}[Hardware Error]: secondary_bus: 0x00
[ 4405.354219] {1618}[Hardware Error]: vendor_id: 0x8086, device_id: 0x4140
[ 4405.354220] {1618}[Hardware Error]: class_code: 010802
[ 4405.354220] {1618}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0000
[ 4405.354220] {1618}[Hardware Error]: Error 2, type: corrected
[ 4405.354221] {1618}[Hardware Error]: section_type: PCIe error
[ 4405.354221] {1618}[Hardware Error]: port_type: 0, PCIe end point
[ 4405.354221] {1618}[Hardware Error]: version: 0.2
[ 4405.354222] {1618}[Hardware Error]: command: 0x0406, status: 0x0010
[ 4405.354222] {1618}[Hardware Error]: device_id: 0000:61:00.0
[ 4405.354223] {1618}[Hardware Error]: slot: 0
[ 4405.354223] {1618}[Hardware Error]: secondary_bus: 0x00
[ 4405.354223] {1618}[Hardware Error]: vendor_id: 0x8086, device_id: 0x4140
[ 4405.354224] {1618}[Hardware Error]: class_code: 010802
[ 4405.354224] {1618}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0000
[ 4405.354225] {1618}[Hardware Error]: Error 3, type: corrected
[ 4405.354225] {1618}[Hardware Error]: section_type: PCIe error
[ 4405.354225] {1618}[Hardware Error]: port_type: 0, PCIe end point
[ 4405.354226] {1618}[Hardware Error]: version: 0.2
[ 4405.354226] {1618}[Hardware Error]: command: 0x0406, status: 0x0010
[ 4405.354227] {1618}[Hardware Error]: device_id: 0000:01:00.0
[ 4405.354227] {1618}[Hardware Error]: slot: 0
[ 4405.354227] {1618}[Hardware Error]: secondary_bus: 0x00
[ 4405.354228] {1618}[Hardware Error]: vendor_id: 0x144d, device_id: 0xa80a
[ 4405.354228] {1618}[Hardware Error]: class_code: 010802
[ 4405.354229] {1618}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0000
[ 4405.354229] {1618}[Hardware Error]: Error 4, type: corrected
[ 4405.354229] {1618}[Hardware Error]: section_type: PCIe error
[ 4405.354230] {1618}[Hardware Error]: port_type: 0, PCIe end point
[ 4405.354230] {1618}[Hardware Error]: version: 0.2
[ 4405.354230] {1618}[Hardware Error]: command: 0x0406, status: 0x0010
[ 4405.354231] {1618}[Hardware Error]: device_id: 0000:61:00.0
[ 4405.354231] {1618}[Hardware Error]: slot: 0
[ 4405.354232] {1618}[Hardware Error]: secondary_bus: 0x00
[ 4405.354232] {1618}[Hardware Error]: vendor_id: 0x8086, device_id: 0x4140
[ 4405.354232] {1618}[Hardware Error]: class_code: 010802
[ 4405.354233] {1618}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0000
[ 4405.354233] {1618}[Hardware Error]: Error 5, type: corrected
[ 4405.354234] {1618}[Hardware Error]: section_type: PCIe error
[ 4405.354234] {1618}[Hardware Error]: port_type: 0, PCIe end point
[ 4405.354234] {1618}[Hardware Error]: version: 0.2
[ 4405.354235] {1618}[Hardware Error]: command: 0x0406, status: 0x0010
[ 4405.354235] {1618}[Hardware Error]: device_id: 0000:61:00.0
[ 4405.354236] {1618}[Hardware Error]: slot: 0
[ 4405.354236] {1618}[Hardware Error]: secondary_bus: 0x00
[ 4405.354236] {1618}[Hardware Error]: vendor_id: 0x8086, device_id: 0x4140
[ 4405.354237] {1618}[Hardware Error]: class_code: 010802
[ 4405.354237] {1618}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0000
[ 4405.354237] {1618}[Hardware Error]: Error 6, type: corrected
[ 4405.354238] {1618}[Hardware Error]: section_type: PCIe error
[ 4405.354238] {1618}[Hardware Error]: port_type: 0, PCIe end point
[ 4405.354239] {1618}[Hardware Error]: version: 0.2
[ 4405.354239] {1618}[Hardware Error]: command: 0x0406, status: 0x0010
[ 4405.354239] {1618}[Hardware Error]: device_id: 0000:61:00.0
[ 4405.354240] {1618}[Hardware Error]: slot: 0
[ 4405.354240] {1618}[Hardware Error]: secondary_bus: 0x00
[ 4405.354240] {1618}[Hardware Error]: vendor_id: 0x8086, device_id: 0x4140
[ 4405.354241] {1618}[Hardware Error]: class_code: 010802
[ 4405.354241] {1618}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0000
[ 4405.354242] {1618}[Hardware Error]: Error 7, type: corrected
[ 4405.354242] {1618}[Hardware Error]: section_type: PCIe error
[ 4405.354242] {1618}[Hardware Error]: port_type: 0, PCIe end point
[ 4405.354243] {1618}[Hardware Error]: version: 0.2
[ 4405.354243] {1618}[Hardware Error]: command: 0x0406, status: 0x0010
[ 4405.354243] {1618}[Hardware Error]: device_id: 0000:61:00.0
[ 4405.354244] {1618}[Hardware Error]: slot: 0
[ 4405.354244] {1618}[Hardware Error]: secondary_bus: 0x00
[ 4405.354245] {1618}[Hardware Error]: vendor_id: 0x8086, device_id: 0x4140
[ 4405.354245] {1618}[Hardware Error]: class_code: 010802
[ 4405.354245] {1618}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0000
[ 4405.354246] {1618}[Hardware Error]: Error 8, type: corrected
[ 4405.354246] {1618}[Hardware Error]: section_type: PCIe error
[ 4405.354246] {1618}[Hardware Error]: port_type: 0, PCIe end point
[ 4405.354247] {1618}[Hardware Error]: version: 0.2
[ 4405.354247] {1618}[Hardware Error]: command: 0x0406, status: 0x0010
[ 4405.354248] {1618}[Hardware Error]: device_id: 0000:44:00.0
[ 4405.354248] {1618}[Hardware Error]: slot: 0
[ 4405.354248] {1618}[Hardware Error]: secondary_bus: 0x00
[ 4405.354249] {1618}[Hardware Error]: vendor_id: 0x144d, device_id: 0xa80a
[ 4405.354249] {1618}[Hardware Error]: class_code: 010802
[ 4405.354250] {1618}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0000
[ 4405.354250] {1618}[Hardware Error]: Error 9, type: corrected
[ 4405.354250] {1618}[Hardware Error]: section_type: PCIe error
[ 4405.354251] {1618}[Hardware Error]: port_type: 0, PCIe end point
[ 4405.354251] {1618}[Hardware Error]: version: 0.2
[ 4405.354251] {1618}[Hardware Error]: command: 0x0406, status: 0x0010
[ 4405.354252] {1618}[Hardware Error]: device_id: 0000:61:00.0
[ 4405.354252] {1618}[Hardware Error]: slot: 0
[ 4405.354253] {1618}[Hardware Error]: secondary_bus: 0x00
[ 4405.354253] {1618}[Hardware Error]: vendor_id: 0x8086, device_id: 0x4140
[ 4405.354253] {1618}[Hardware Error]: class_code: 010802
[ 4405.354254] {1618}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0000
[ 4405.354254] {1618}[Hardware Error]: Error 10, type: corrected
[ 4405.354255] {1618}[Hardware Error]: section_type: PCIe error
[ 4405.354255] {1618}[Hardware Error]: port_type: 0, PCIe end point
[ 4405.354255] {1618}[Hardware Error]: version: 0.2
[ 4405.354256] {1618}[Hardware Error]: command: 0x0406, status: 0x0010
[ 4405.354256] {1618}[Hardware Error]: device_id: 0000:01:00.0
[ 4405.354256] {1618}[Hardware Error]: slot: 0
[ 4405.354257] {1618}[Hardware Error]: secondary_bus: 0x00
[ 4405.354257] {1618}[Hardware Error]: vendor_id: 0x144d, device_id: 0xa80a
[ 4405.354258] {1618}[Hardware Error]: class_code: 010802
[ 4405.354258] {1618}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0000
[ 4405.354258] {1618}[Hardware Error]: Error 11, type: corrected
[ 4405.354259] {1618}[Hardware Error]: section_type: PCIe error
[ 4405.354259] {1618}[Hardware Error]: port_type: 0, PCIe end point
[ 4405.354259] {1618}[Hardware Error]: version: 0.2
[ 4405.354260] {1618}[Hardware Error]: command: 0x0406, status: 0x0010
[ 4405.354260] {1618}[Hardware Error]: device_id: 0000:61:00.0
[ 4405.354261] {1618}[Hardware Error]: slot: 0
[ 4405.354261] {1618}[Hardware Error]: secondary_bus: 0x00
[ 4405.354261] {1618}[Hardware Error]: vendor_id: 0x8086, device_id: 0x4140
[ 4405.354262] {1618}[Hardware Error]: class_code: 010802
[ 4405.354262] {1618}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0000
[ 4405.354263] {1618}[Hardware Error]: Error 12, type: corrected
[ 4405.354263] {1618}[Hardware Error]: section_type: PCIe error
[ 4405.354263] {1618}[Hardware Error]: port_type: 0, PCIe end point
[ 4405.354264] {1618}[Hardware Error]: version: 0.2
[ 4405.354264] {1618}[Hardware Error]: command: 0x0406, status: 0x0010
[ 4405.354264] {1618}[Hardware Error]: device_id: 0000:61:00.0
[ 4405.354265] {1618}[Hardware Error]: slot: 0
[ 4405.354265] {1618}[Hardware Error]: secondary_bus: 0x00
[ 4405.354266] {1618}[Hardware Error]: vendor_id: 0x8086, device_id: 0x4140
[ 4405.354266] {1618}[Hardware Error]: class_code: 010802
[ 4405.354266] {1618}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0000
[ 4405.354267] {1618}[Hardware Error]: Error 13, type: corrected
[ 4405.354267] {1618}[Hardware Error]: section_type: PCIe error
[ 4405.354267] {1618}[Hardware Error]: port_type: 0, PCIe end point
[ 4405.354268] {1618}[Hardware Error]: version: 0.2
[ 4405.354268] {1618}[Hardware Error]: command: 0x0406, status: 0x0010
[ 4405.354269] {1618}[Hardware Error]: device_id: 0000:61:00.0
[ 4405.354269] {1618}[Hardware Error]: slot: 0
[ 4405.354269] {1618}[Hardware Error]: secondary_bus: 0x00
[ 4405.354270] {1618}[Hardware Error]: vendor_id: 0x8086, device_id: 0x4140
[ 4405.354270] {1618}[Hardware Error]: class_code: 010802
[ 4405.354271] {1618}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0000
[ 4405.354272] AER: buffer overflow in recovery for 0000:61:00.0
[ 4405.354272] AER: buffer overflow in recovery for 0000:01:00.0
[ 4405.354273] AER: buffer overflow in recovery for 0000:61:00.0
[ 4405.354274] AER: buffer overflow in recovery for 0000:61:00.0
[ 4405.354275] AER: buffer overflow in recovery for 0000:44:00.0
[ 4405.354275] AER: buffer overflow in recovery for 0000:61:00.0
[ 4405.354276] AER: buffer overflow in recovery for 0000:01:00.0
[ 4405.354276] AER: buffer overflow in recovery for 0000:61:00.0
[ 4405.354277] AER: buffer overflow in recovery for 0000:61:00.0
[ 4405.355541] pcieport 0000:60:01.1: AER: aer_status: 0x00001000, aer_mask: 0x00000000
[ 4405.355543] pcieport 0000:60:01.1: [12] Timeout
[ 4405.355544] pcieport 0000:60:01.1: AER: aer_layer=Data Link Layer, aer_agent=Transmitter ID
[ 4405.355546] pcieport 0000:60:01.1: AER: aer_status: 0x00001000, aer_mask: 0x00000000
[ 4405.355547] pcieport 0000:60:01.1: [12] Timeout
[ 4405.355548] pcieport 0000:60:01.1: AER: aer_layer=Data Link Layer, aer_agent=Transmitter ID
[ 4405.355548] pcieport 0000:60:01.1: AER: aer_status: 0x00001000, aer_mask: 0x00000000
[ 4405.355549] pcieport 0000:60:01.1: [12] Timeout
[ 4405.355550] pcieport 0000:60:01.1: AER: aer_layer=Data Link Layer, aer_agent=Transmitter ID
[ 4405.355550] pcieport 0000:60:01.1: AER: aer_status: 0x00001000, aer_mask: 0x00000000
[ 4405.355551] pcieport 0000:60:01.1: [12] Timeout
[ 4405.355552] pcieport 0000:60:01.1: AER: aer_layer=Data Link Layer, aer_agent=Transmitter ID
[ 4405.355552] pcieport 0000:60:01.1: AER: aer_status: 0x00001000, aer_mask: 0x00000000
[ 4405.355553] pcieport 0000:60:01.1: [12] Timeout
[ 4405.355553] pcieport 0000:60:01.1: AER: aer_layer=Data Link Layer, aer_agent=Transmitter ID
[ 4405.355554] pcieport 0000:60:01.1: AER: aer_status: 0x00001000, aer_mask: 0x00000000
[ 4405.355555] pcieport 0000:60:01.1: [12] Timeout
[ 4405.355555] pcieport 0000:60:01.1: AER: aer_layer=Data Link Layer, aer_agent=Transmitter ID
[ 4405.355556] pcieport 0000:60:01.1: AER: aer_status: 0x00001000, aer_mask: 0x00000000
[ 4405.355556] pcieport 0000:60:01.1: [12] Timeout
[ 4405.355557] pcieport 0000:60:01.1: AER: aer_layer=Data Link Layer, aer_agent=Transmitter ID
[ 4405.355558] pcieport 0000:60:01.1: AER: aer_status: 0x00001000, aer_mask: 0x00000000
[ 4405.355558] pcieport 0000:60:01.1: [12] Timeout
[ 4405.355559] pcieport 0000:60:01.1: AER: aer_layer=Data Link Layer, aer_agent=Transmitter ID
[ 4405.355560] pcieport 0000:60:01.1: AER: aer_status: 0x00001000, aer_mask: 0x00000000
[ 4405.355560] pcieport 0000:60:01.1: [12] Timeout
[ 4405.355561] pcieport 0000:60:01.1: AER: aer_layer=Data Link Layer, aer_agent=Transmitter ID
[ 4405.355561] pcieport 0000:60:01.1: AER: aer_status: 0x00001000, aer_mask: 0x00000000
[ 4405.355562] pcieport 0000:60:01.1: [12] Timeout
[ 4405.355562] pcieport 0000:60:01.1: AER: aer_layer=Data Link Layer, aer_agent=Transmitter ID
[ 4405.355563] pcieport 0000:60:01.1: AER: aer_status: 0x00001000, aer_mask: 0x00000000
[ 4405.355564] pcieport 0000:60:01.1: [12] Timeout
[ 4405.355564] pcieport 0000:60:01.1: AER: aer_layer=Data Link Layer, aer_agent=Transmitter ID
[ 4405.355565] pcieport 0000:60:01.1: AER: aer_status: 0x00001000, aer_mask: 0x00000000
[ 4405.355565] pcieport 0000:60:01.1: [12] Timeout
[ 4405.355566] pcieport 0000:60:01.1: AER: aer_layer=Data Link Layer, aer_agent=Transmitter ID
[ 4405.355567] pcieport 0000:60:01.1: AER: aer_status: 0x00001000, aer_mask: 0x00000000
[ 4405.355567] pcieport 0000:60:01.1: [12] Timeout
[ 4405.355568] pcieport 0000:60:01.1: AER: aer_layer=Data Link Layer, aer_agent=Transmitter ID
[ 4405.355569] pcieport 0000:60:01.1: AER: aer_status: 0x00001000, aer_mask: 0x00000000
[ 4405.355569] pcieport 0000:60:01.1: [12] Timeout
[ 4405.355570] pcieport 0000:60:01.1: AER: aer_layer=Data Link Layer, aer_agent=Transmitter ID
[ 4405.355573] nvme 0000:61:00.0: AER: aer_status: 0x00000001, aer_mask: 0x00000000
[ 4405.355573] nvme 0000:61:00.0: [ 0] RxErr (First)
[ 4405.355574] nvme 0000:61:00.0: AER: aer_layer=Physical Layer, aer_agent=Receiver ID
[ 4405.355576] nvme 0000:61:00.0: AER: aer_status: 0x00000001, aer_mask: 0x00000000
[ 4405.355576] nvme 0000:61:00.0: [ 0] RxErr (First)
[ 4405.355577] nvme 0000:61:00.0: AER: aer_layer=Physical Layer, aer_agent=Receiver ID
In attempting to move the hardware in and out to diagnose, I get various issues in addition to the above such as not getting any video or a complete inability to boot. The current state I am in now, I cannot boot with any of the 980s or Optane drives/cards connected to the system.
I have swapped the motherboard and remounted the CPU once. All ram tests pass fine. Same issue persists despite.
