Ok so here we go, I am sorry if this is the wrong forum but it was all that suited prime95.
So I just finished my build and am using a FX 8350 NOT OVERCLOCKED with stock cooler on a M5A99FX Pro R2.0 motherboard. My RAM is corsair vengeance 1600- 8GB.
I ran prime95 and my temps sat around 60-63 degrees Celsius.
But what was odd is when I started it around 30 seconds in, cores 7 and 8 failed.
Core 7 says: ERROR ILLEGAL SUMOUT
Core 8 says: FATAL ERROR: Rounding was 0.5 expected less than 0.4
I am stressing about it heaps. Are my cores faulty? Is it hardware? Software?
Please set CPU voltage from offset to manual @ 1.38v, make sure turbo is off. Might even be worth pulling the cmos battery out an in, to wipe bios settings. Try turning cool and quite / all other power saving settings off.
Your Northbridge and vdda voltages and also your psu are fine.
Ok, so I activated manual, turned off AMD core boost technology and disabled cool/n/quiet, so my voltage runs at 1.368 to 1.398 all the time. I ran prime95 again but this time, in stead of keeping around 61* it went to 65. I stopped it at 65 incase I would destroy my CPU but hey! None of the cores crashed! I am using the stock cooler so I assume that my high temps are from that?
^ Cooper can you shed some more light on that? If prime95 isn't a good stability test then why is it THE stability test recommended on every major Overclocking forum. A source or explanation would be interesting, I use Aida64 as well it is a great utility.
Aida64 uses all of the instruction sets including the new ones in Haswell and Piledriver/trinity/richland cpus while Prime95 does not prime will allso draw more power than it is supposed to and can actually do more harm than good.
Prime 95 is a very old program and is not optimised for todays new cpu architecture's the last time it even had a update was dec 2012.
