Prime95 annoying issue keeps running in the background
I have this slight issue when I first ran P95 I accidently chose the non Stess method and now this method keeps popping up in the background and torturing my poor Xeon 1231v3 when I don't want it to. Can you make sure that this evil program is only used when I want to.
ps. Yes I added a crappy story while writing this post.
The easiest thing to do would be to just completely uninstall P95 and reinstall it which will most likely also remove the seemingly scheduled start of the stress.
Otherwise you could try to locate this in the options somewhere and remove it or you could go to startup (If you're running windows)
And then remove P95 from the startup if it is there
Completely forgot about that. Thanks for reminding me.
