I don't really know what the correct name for this thing is, they call it a network termination device. It sits between my router and the wireless transceiver on the roof, it provides power to the transceiver and has four ethernet ports which are for different services (so not a switch but probably each is a different VLAN, I'm not really sure how it works or what the other services would be).
It isn't (as far as I can tell) a router, it only appears to have the one, public, IP which I can see when monitoring my WAN interface. But I really don't know, I haven't been able to find any meaningful documentation for it.
I don't believe it is running NAT, I have a public IP on my WAN interface that I get from the ISP and the address of the box is not my gateway, I really don't know how it works though, there's no authentication on the router but the box would have some kind of ID that is used to connect the service to my account. There is no web login, or internal IP address, and no brand, it's just a NBN network termination device.
But if it was running NAT it still shouldn't be able to see anything on my LAN and my LAN doesn't have a route to it, not a direct one anyway without going to the ISP gateway and back again.
Running ntpdc gives me version 4.2.8 but nmap says 4.2.6. But yeah, I'll call my ISP tomorrow and hopefully get this sorted out. Thanks again, you've been awesome
I am absolutely furious at the moment. I can understand that some call centre stooge from India is not going to be able to help me, but they could at least help me get in contact with someone who can rather than tell me that the problem is I'm not using the ISP modem (they mean router).
It's annoying that my modem is spewing NTP traffic out and slowing my internet down, sure, but what really makes me angry is that there is a box between me and my ISP that gives remote access to essentially the government, AND that it's vulnerable to known exploits meaning that anyone could take control of it potentially.
And even if the government does something about it god knows how much taxpayer money it's going to cost to fix.
Anyway, on Monday I will try my ISP again and hopefully I can talk to someone who actually works at Optus and therefore might give a shit, but failing that I'm probably going to take this up with the Ombudsman.
In the mean time I'm thinking if I can get in between the network termination device and the antenna I could put a firewall in. But A) The antenna is powered by PoE, I have some injectors but I'm not sure what will happen if I try it and it's not using the PoE standards. and B) If they figure out that I have done that they will probably fine me or something.
