So since Windows is a dickhead and does not like to cooperate smoothly with a dual boot config, and anyways I'm tired of spending more time troubleshooting shit that enjoying my PC I decided that I'm doing a Linux only setup. I'm going to use brennanriddell's installation guide (http://pastebin.com/74DahAfs). However, should I just run a pass of DBAN over my HDD or what? Are there quicker alternatives? Also should I delete my partitions from Windows? I want my hard drive to be as clean as possible prior to installing Arch.
Well if you want the hdd as clean as possible then spend the time and do a few passes of dban. Since you aren't offloading the hdd then all I'd personally do would be 1.
Also why keep any windows partitions anyway? Boot em off if you're going single boot.
Just use the Arch installation to delete all the partitions.
This.
gdisk is good, easy to use.
How do you add a new hd after the install?
Well, the easiest way is to make a manual addition to your fstab.
No I meant should I delete the partitions from a tool inside Windows, my bad that was badly worded.
I had problems with the UEFI boot, I get an error and can't even do it. Even though I'm 99.999999999% my hardware supports it.
Cool thanks
What bootloader did you use, and what are the errors?
If you're using any recent DE, and you don't need the disk to be permanently mounted on in a specific location you could also rely on your DE to mount the disk, in GNOME you will see the hdd on the side panel and only need to click it to run.. but ofcourse on the long run, and for automount cases you need fstab entries
cfdisk within the arch boot cd. Or you can use an Ubuntu live CD and I like to use gparted since it is a GUI partitioning tool. It is very very useful.
