My renders out of premiere cc always looked great on youtube until a few weeks ago. Now when I render I get really good quality when there's low/no motion in the video, but as soon as motion starts I get this really bad pixelated motion blur. Never used to happen and as far as I know I'm still using the same render settings as I always have in premiere and the same raw recording settings in dxtory. The renders look great before I upload to youtube, but as soon as youtube does their conversion it's pretty bad. Leads me to believe that my render does not do well with youtube's conversion settings. If anyone cares to share a tried and true 1920x1080 premiere render that looks great on youtube I'd appreciate it.
Are you sure that it isn't due to the compression on youtube? I know that i have noticed things like that in my own videos before but its generally only noticeable to me because I made the original file. It sounds like yours is considerably worse though.
Are you sure that the video has been fully processed before seeing if the problem is still there? It could easily just be that the video is not fully processed yet. I see that I have replied to you quite a while after your original post, is the problem still currently happening?
Its still happening. Same on all my videos, and after processing is completely finished. For example: https://www.youtube.com/watch?v=McuziWaci_Q
That video is the worst example. Some of the others aren't as bad, but its still present. The above video I exported at VBR 2 pass, max bitrate 60, target 60. 60 is crazy high for youtube but there you go. :P
