I've been looking at extending my home network recently, so invested in four TP-Link 500Mbit Powerline Adapters. Unfortunately, I've just realized that my NIC's are running at 100Mbps, not 1Gbps. I did the checks and it's only downgraded when using the adapters. I realize that I would never get the full use of the 1Gbps regardless, but I had hoped to get a somewhat faster connection between the PC's in my home. As the adapters were advertised as having a Gigabit Ethernet port, I find this pretty annoying.. basically I paid for 500Mbit Adapters, when the 200Mbit would have given me exactly the same speeds. I did a little further digging and it turns out the PORT is Gigabit, BUT everything past the port (still inside the adapter) is not.
Anyway, I'm going to cut my losses and sell the adapters to recoup some of the money spent. The big question is where do I go from here for my home network. The computers are dotted around the home, so I'm thinking my only solution is to run cables behind the skirting boards. I really don't fancy messing about with anymore powerline adapters.
Is running CAT5e cable around my home the best way to do this? Any alternatives?
Many thanks..
