I was looking at Buildzoid’s videos about the 6900XT, but I can’t find any teardowns for the 6950XT (at least for the two which are on offer).
But I just took another look, and the MERC is now 60€ cheaper (629€).
I took a look at TechPowerUp and got out these numbers:
There is no data on their site for the Merc and the Red Devil. If I assume that the Merc will behave similar to the reference (2x8pin) and the Red Devil as any of the other 3x8 pin custom models, that means that the transients are going above the maximum (theoretical?) deliverable power less for the 3x8 pin models.
However, the maximum power spike is also increased. And these transients are measured at 20 ms. Gamers Nexus showed at 100 μs that the transients can go more than double the normal maximum power draw.
So, going by the TechPowerUp numbers, as a worst case scenario, I can expect the 100 μs transient to go up to around 2x415 = 830 W.
Right now, I have an EVGA 850 BQ, 80+ Bronze PSU - which is rated at max of 840W at the 12V rail (70A). But the thing is, I got it late 2018.
So my question is this: is the 3x8 pin a detriment or a benefit? Does it make the problem of transients worse, by allowing the power to go above what my PSU can provide, or does it help (somehow)? If I buy the cheaper 2x8 card (with potentially worse fans), will I avoid this problem?
EDIT: Also, for anyone that says there won’t be any performance difference in games - I do know that. I would also like to add that IF (and that’s rather a big if) AMD does something with the ROCm and would like to do some GPU compute. In addition, I play Star Citizen from time to time, and that game is notoriously badly optimized - so these problems with transients can potentially affect me.
