://m.newegg.ca/products/N82E16817139205
is this any good its pretty cheap compaired to every other 1200 80plat psus... frim what i seen its on tier 1 list can confirm? please me me know this is for my custom loop build
://m.newegg.ca/products/N82E16817151166
found this alwas curious i know its only gold but thats fine...
this one is great, and price is good.
I always use enermax (tho in their solution you'd pay around $500 for 1200+ 80+ gold)
You may try this, but i never used evga
what one the seasonic or corsair
seasonic.
oh thats not enough wattage for me...
i need a 1200 im tryong to run 2 fury x 1700x full custom loop with 1 d5 pump nd 3 ssds 6 fans...
you'd be fine with 850W for that.
really even under full loads overclocked? i hear lots of people having issues with 1k and under
depends on psu, if you get platinum or titanium rated; you'll be just fine.
I had 4x 290x overclocked running with 4 SSD's, and aio (with plenty fans) on single 850W enermax platimax
When you look at power consumption for fury-x, note those numbers are for full system load (not gpu only)
so if you have 2x fury-x you'd be close to 600W
so should i get a 1000 plat? i only got 374 canadian to a psu
note it depends on the psu make, some will allow you push more out of them, some will shut down. Thats why its important to get good one.
seasonic is one of the best out there.
should i just grab the 1200 seasonic?
even tho its just gold rated or should i get the corsair since its 80 plat
seasonic is better brand, they'll likely used better components than corsair.
The 1200 will leave you with headroom regardless.
how are the warrentys of each. i really wa ted evga i may just wait a month nd grab a plat evga and post pone my build for a month
i'd say seasonic warranty is better 5-7-12 years.
ok so i should be good grabbing the 80 gold seasonic and i shouldnt hsve issues. im not one for actually learning much into psus lol
yea, good luck on your build.
thanks its been since ryzen relse ive been earning parts lol
