Power supply
fsp 400 http://www.amazon.com/FSP-Group-U-S-A-CorporationAURUM-AS-400/dp/B00BZIIEDG/ref=sr_1_19?ie=UTF8&qid=1366668065&sr=8-19&keywords=fsp+aurum
rosewill 450 http://www.amazon.com/Rosewill-CAPSTONE-Certified-Modular-CAPSTONE-450-M/dp/B0081XXIHK/ref=sr_1_27?s=electronics&ie=UTF8&qid=1366668283&sr=1-27&keywords=rosewill+power+supply
rosewill 550 http://www.amazon.com/Rosewill-BRONZE-Certified-ATX12V-Hive-550/dp/B005ILWY9G/ref=sr_1_3?s=electronics&ie=UTF8&qid=1366668345&sr=1-3&keywords=rosewill+hive
xfx 450 http://www.amazon.com/XFX-ATX-450-Power-Supply/dp/B005FPT38U/ref=sr_1_1?s=electronics&ie=UTF8&qid=1366668363&sr=1-1&keywords=xfx+450
cx 600 http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028
What one do you think and why?  It would be powering a i5 3570k @ 4.3 and a 7870
http://www.newegg.com/Product/Product.aspx?Item=17-151-106&nm_mc=EMC-GD042213&cm_mmc=EMC-GD042213-_-index-_-Item-_-17-151-106 this is on sale for like $60 after MIR.
That one is pretty sweet just not a huge fan of MIR
ya but right now its 75 with out it so if you dont do the MIR its still a really good deal.
cheaping out on the PSU is a really, really bad idea. a cheapo psu will have shitty voltage regulation, and probably won't be able to supply the rated wattage. beyond that, the voltage fluctuations may kill your hardware. it's happened before.
I would not say $70 is cheaping out and I don't see any need to drop like $100 on a psu I know all the ones I put in my list are good.  BTW that psu is still $90 don't know where this $60 is coming from.
promo code from 90 to 75 MIR brings it down to 60  if you think your cheaping out by buying this psu you are mistaken.
Ya I figured out the sale on it and I was just making a point to him that a $60-$70 psu is not cheaping out.  I think I am going to purchase that right now thank you for pointing out this deal.
The Rosewill Capstone 450 will do; the Capstone series really stepped up the quality, and is on par with the Seasonic X series. However, some of them have really loud fans :( If you wanted, you could open up the PSU, and replace the fan, but that would most definitely void the warranty. Instead, you could get a Seasonic G 550; fully modular, unlike the Rosewill, and very well built. $30 more, but worth it for the modularity and silence :)
so should I get the rosewill 450 gold or the seasonic m12ii 650 bronze? they are about the same price
or this one: http://www.newegg.com/Product/Product.aspx?Item=N82E16817153169
you can get it for 70 dollars afther 30 dollar  rebate
or http://www.newegg.com/Product/Product.aspx?Item=N82E16817151094
or http://www.newegg.com/Product/Product.aspx?Item=N82E16817182200
I guess the whole MIR this is confusing./....
