Power Supply Power Draw?
If I have a 15 AMP breaker in my room will I be able to use my computer without blowing it with these specs?
Gigabyte GA-78LMT-USB3 AM3+ CVDO X16 4D3 M32 GL R MATX Motherboard
Fx 4170
Gtx 770 4gb OC
8GB Ram
500GB HDD
1 Optical Drive
CorsairCX 750
it won't blow your electric circuits...
A 15 AMP circuit can probably handle around 1500 watts
I agree your system will probably pull no more than 250 W from the wall when working hard.
Depending on your line voltage which is somewhere around 110-120 Volts, 250 W is equivalent to 2.25 Amps.
So the computer will use a small fraction of your circuit's capacity.
If your room is a typical bedroom all outlets in the room are on the same 15 A circuit.  The items to watch out for are heaters, toasters, hair dryers, kettles, coffee machine, anything with a heater in it.  Any one of those by itself can use up 75% of a circuit.
