Hello everyone, I am having a problem and I think I know the answer but I want to get other opinions. Ok, so I recently put together a new build and it runs great but when I open demanding programs/ games my computer just shuts off. I have checked CPU temps and they are hovering around 8 degrees Celsius so its not an over heating issue. Its also not a RAM or HDD/SSD problem as far as I can tell. My idea for what is causing this is my power supply is underpowered for my build.
Spec list-
AMD FX-8350
Asus M5A99FX PRO R2.0
Adata XPG 16 GB (2XGB)
XFX R9 280X
Kingston HyperX 3K 120gb
Western Digital Blue 1TB
Coarsair H100I
Old Thermaltake 700 Watt (temporary power supply due to backorder)
The power supply I ordered with everything above is on back order (RM 850). Temporarily I am using an old Thermaltake 700 Watt power supply. Its older so its not 80 plus certified or anything like that. My suspicion is the power supply peak wattage is 700 watts but that isn't what it provides continuously and it dips below what my computer is using and causes it to shut off. Am I totally wrong here? I dont think I will have this problem with the RM 850... What else could be causing it?
The 700W I am using is really old so I am hoping that is the problem. The power supply gets quite warm which is what led me to think it was the power supply.
Most likely the Thermaltake PSU is faulty because 700W is overkill for this build and even capacitor aging can't bring it down to the point where it is underproviding.
Thats the thing, this power supply worked fine in an old build (albeit in one that hardly drew any power). The old build was a Core 2 Duo 8gb or RAM and a GT 630. A completely different spectrum from this build. (also I didnt build that "build" I have no idea why that power supply was in it.)
well that RM850 you getting is a bit overkill haha, you can run a CF R9-280X and overclock the hell out of your system, and you will still have headroom ☺
Yes, I have tried reconnecting the power connectors. I am not getting any beep errors or blue screens just plain shut offs. Yes I am using a surge protector.
Yeah, I went for the 850 for the headroom and the fact that if I needed to add more hard drives and maybe Crossfire the graphics card in the future I would be able too.
My guess is that you're right to suspect the power supply, because the behavior sounds like a power issue.
It all depends on exactly what PSU you are using, Thermaltake makes a lot of PSUs. I don't know but I'm willing to bet that 5-10 years ago, a "700" Watt power supply was not close to what it is today, because system needs were much lower back then. Also, system requirements have shifted to the 12 V rail over that time. Look at the label where it calls out how many Amps are available at each voltage. Your CPU needs 10 Amps and the GPU needs about 15. The PSU probably has multiple 12 V rails in which case double check that the CPU gets one to itself and the GPU gets one to itself. The HD is probably not a problem but you can disconnect it if you want to try that.
I'd agree with Reservation about the PSU then. Try checking the BIOS to make sure there's no overclocked/overvolted funny business going on in there. I'd say if there isn't then the PSU is the dodgy. If that's the case you could try underclocking/undervolting your system so that you could use it in the meantime while you wait for your new PSU to arrive.
Yeah, thanks! The only other power supply I have laying around is a 430 watt... I'm relatively sure that is just to low to put in there and see if its power supply I have currently in the machine.
It might be OK. Your best bet is to look at the label on the PSU casing where it tells you how many amps are available at each voltage. 430 Watts is sufficient for your needs, problem is the PSU probably won't deliver them.
