Power Supply for R9 290
I wonder if this power supply can power my system with the new AMD Radeon R9 290.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341017
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013
I own these power supplies and don't want to buy a new one.
My specs:
AMD FX 8320 @ 4.1ghz (Can put back to stock or lower clock rate.)
AMD Radeon R9 290 (Just bought)
Samsung 840 evo 120gb ssd
2x2gb + 2x4gb = 12gb
Two 7200 rpm seagate drives.
6 case fans
CoolerMaster 212 evo heatsink push and pull (2 fans)
PCI wifi card
DVD RW
Most demanding thing I do is render videos and play BF4.
I just need to know if I can do what I need to do without buying a new power supply, due to my minimal wage problem.
The link you posted doesn't work.
Any decent PSU with 550W or more and over 45A or so on the 12V rail will be fine. No need to mess with your OC.
I fixed the links in OP. So my XFX power supply will work fine?
Yes you should be fine.
Agreed, even with an OC you should be ok
yes 550W is more then enough.
Full system load with an R9 290 is ~400 watts FYI
http://www.anandtech.com/show/7481/the-amd-radeon-r9-290-review/15
http://www.tomshardware.com/reviews/radeon-r9-290-and-290x,3728-4.html
Those PSUs seem good but if you want another option I am a huge advocate of the Corsair CX750M. it performs well with my overclocked 4770k and 290x, it was very good value for money and will allow me to add a second 290x later on. If you want to save a little and wont be using much more power than your current load then a CX500m would do just fine.
