Power Supply for Dual GPU AM5 Build
Hi,
I was wondering if anyone could help me plan on how beefy of a power supply I’ll need to power two Nvidia 3000/4000 series or equivalent Radeon GPUs? How should I go about calculating this? Also, any suggestions on brands?
There are various calculators to be found online.
Check reviews on a per unit basis.
The psu tier list from psucultists is pretty nice. You can either find a psu and check if its in the list or take one from the list. You can also use PCPartsPicker to calculate wattage. Just add all your components and it will give you an estimate.
PSU Tier List: PSU Tier List rev. 16.1A - Cultists Network
PCPartsPicker: Choose Your Parts - PCPartPicker
Look at the warranty length, shows a lot about quality of product. OEMs such as superflower/seasonic are good options
