Power consumtion with use of pfsense
hello guys!! i have been to sites for pfsense hardaware....and i have made up my mind by installing pfsense on my 7 year old intel dual core e5200.....and make it a source of torrenting and bittorrent sync client......but what i want to know is what wil be typical power usage of this config..will it be similar to a normally windows 7 pc or less then that?? or will it use all the power it can to provide routing duties....i m using a 300W psu,3gb ram., 250gb hdd AND 3  LAN cards....
THANK YOU!
and teksyndicate team .... YOU KNOW YOU ARE AWESOME!! KEEP THOSE VIDEOS COMING!
Well its linux/BSD so, it will need less for more. :P
well yes....but what would be the approx???
if you are talking wattage, nothing will change.
if you are talking resources, everything will change.
hmmm so 300W is overhead but usage will be significantly less.....i have been experimenting with ddwrt on my tp-wr1043nd....and i m not satisfied....
