I would go with EVGA. they are great support and if you need any help there support is 24/7 and there are nice ppl on forums to help out. I'm there also.
but yes i would go with EVGA. just for so many reasons i cannot make a list of them all.
I ran almost the extact same build expect its amd. It works on a 450Watt PSU, but im probably gonna get an upgrade cause the PSU probably wont last for too long. I also oc my cpu. If you want to be sure wat your systems' power usage use eXtreme Power Supply Calculator. Just google it. Also with intel ram speeds does not show a big performance increase, but with amd it does, but i would stil aslo recommend 800mhz ram
Also i have the Evga 8800 GS. It overclocks really really well i'm playing crysis on high 1280 1024 no aa averaging 30fps. The card also runs really silent and cool, much more different than the XFX 8800 GS, That card from i've read online is hot n noisy
definitely get a 500-600 watt power supply, you never know when you want a new graphics card and you power supply isn't up to snuff either, buy a bigger one now and save yourself some hassle, I wish I did...
