ok so i am having my silver stone tj07 powder coated, the finish that i am going to use is black chrome II.
http://www.shop.allpowderpaints.com/BLACK-CHROME-III-PCGB05591.htm
i have also been thinking about powder coating my cpu heat sink the noctua d14, and i was wondering about thermal performance and i was wondering what it would do.
thanks,
carter
i would stay away from putting it on the heatsink. It would definitely impede the heatsink's ability to dump heat into the air; though, how much is hard to say.
No, it wont effect performance at all, as long as you dont coat the copper bottom that actually touches the CPU.
An make sure that you don't clog up the fins when you are applying it, or else it will effect performance. But if you get an even thin coat you should be fine, and as Phantom said don't get any on the contact point to the cpu.
wouldn't the powdercoat be a less effective medium to dissipate the heat into the air? I'm not saying you guys are wrong, I'd just like to know why?
Seems like the extra coating would insulate the heatsink net higher temps.
yeah thats what i was thinking I am still debating whether do do it
It will decrease the performance of the heat sink because you are putting a layer of plastic over the metal. However if a thin coat is applied and if you add a metallic pigment these will both help reduce the plastic coating from inhibiting the heat transfer. Either way it will perform worse than a bare metal heat sink but it shouldn't effect the temperatures by too much. And if you are still iffy on the idea you can always just powder coat parts of the heat sink as opposed to the entire thing, like just the top and base but leave the fins how they are so that they can exchange heat the best.
is there anyway that i can prevent this i am having it done
