Hey could any of you guys give me some help im trying to stay with in a budget of about £470 - £550. I will be streaming and recording games ith this computer.
Specs:
GPU: Asus AMD Radeon HD 6670 2GB (Already have)
MOTHERBOARD: Asus M5A97 EVO R2.0 Motherboard
CPU: AMD FX 8350
COOLING: Cooler Master Hyper 212 EVO (120mm)
CASE: Aerocool Strike-X One Screwless Mid Tower Gaming Case
RAM: Corsair CMZ8GX3M2A1600C9 Vengeance 8GB (2x4GB) DDR3 1600 Mhz
STORAGE: Seagate Barracuda 3.5 inch 2TB 7200 RPM 64MB 6GB/S Internal SATA Drive
PSU: Corsair Builder Series CXM 750W Modular 80 PLUS Bronze Certified ATX/EPS PSU
Recommendations welcome :)
I would place the 8350 on a 990 chipset motherboard. Alternately, you can grab a 8320, which should allocate enough budget for a better motherboard.
What other motherboards would you reccomend i can spend upto about £550 and im currently spending £504
I would keep everything except the CPU. Get a fx 6300 it's the best bang for the buck gaming cpu trust me(I have it). I record games, render vids, and streaming. Yes the 8 core is better but overall for the price you just cannot beat the 6300.
Well the Asus M5A97 EVO R2.0 is a great budget board for the FX8350. its not the same board as the Asus M5A97 R2.0!
The Asus M5A97 evo r2.0 has a 6+2 power phase and digi vrm, same powerphase and vrm design as the M5A99FX pro R2.0 so its a great board. only its not realy made for cf or sli.
i own this board myself.
