Background:
While I already have a mostly adequate laptop, it has temperature and stability issues, along with poor Linux compatibility, causing me to look into desktops to replace the laptop for desk use, since it will still handle portable use fine.
However, to my mind I can’t just get something equivalent to the laptop, as there is no point in getting something new unless it either does something new or improves on the old performance.
Current Thoughts:
So I have been on ebay recently, looking at older workstations. The ivy/sandy bridge dual socket models seem to have a good price for what you would actually get with them.
I am currently thinking that a dual 6 core configuration would be my best choice, provided I can get a per-core performance similar to my current laptop. If possible, this would mean I would have a substantial performance increase for multitasking/vms (question about vms on these platforms to come below), while not losing performance for gaming (with an upgraded gpu fitted of course)
However, the possibility of good vm performance brings up another point/question; Is PCIE passthrough to a vm possible on this type of platform, and if so, should I consider tailoring the system for it?
Options:
[uk]
There are two main options for a second hand workstation that I have found: Lenovo c30 or HP z620. The Lenovo c30 seems much better priced than most hp z620s, but does generally come with two lower end cpus, however I would probably want to replace the cpus in any system with higher end v1 or v2 xeons (aiming for 3+ GHz sustainable clock during heavy use, to not suffer much loss in single thread from my existing laptop) (any machine with v2 should be compatible with both generations, similar to haswell/broadwell?)
The lenovo c30 does appear to have one major disadvantage compared to the hp z620: It will be much harder to fit a decent graphics card for 3d use, due to the very low profile height above the pcie slots. This would require finding a card no taller than a pci slot cover, and with power ports on the back rather than the top of the card. The power supply may also not have outputs for a graphics card. c30 units with 16G of ram (win7 is most common os bundled) seem to go for ~£300
HP z620 units are more expensive generally (~£550), but have space for easily fitting graphics cards (either 400ish or 800ish watt power supplies). The cpus in them will have a little more resale value, but are probably not good for my workload, and most are v1 only. A sort of card is used for a second cpu, so these would have to be bought with two. I think the lenovos would only require a cooler to fit a second cpu.
Xeon E5-2609v2 are the processors I have found c30 units with, and would certainly need replacing (default cooler cools up to either 130 or 160 watt cpus).
HP units I have seen with processors like Xeon E5-2620, which would still need replacing, but I have no idea about the cooling limits.
I can buy Xeon E5-2667 for ~£50 each, which would be suitable for either system type, but most second hand xeons I have found have a piece of blue plastic around the heatspreader, can it be removed? (like in this add, not one I want to buy: https://www.ebay.co.uk/itm/Matched-PaIr-Intel-Xeon-E5-2670-V2-2-5GHz-10-Core-25MB-SR1A7-Processor-/142720178694?_trksid=p2349526.m4383.l4275.c10)
Along with the above, I have found E5-2667 V2 (@~£240, probably for a pair), E5-2630 V2 (@~£100 each), what do you guys think?
If I go for a new system (one of this sort), GPU would most likely be either gtx 1060 6G or RX 580 8G, which seem to be reasonable prices. I already have a 512GB SSD I can probably take from my laptop (it is storage drive, not boot) for a boot disk (only in that machine just now so I can actually use it for something)
My budget for a system (minus GPU and storage, but with any CPU upgrades) would ideally be max £600, <£520 would greatly increase my chances of actually being able to go for it.
So what are you guys thoughts on these system ideas? Any replies with opinions on my rationale and answers to my questions would be much appreciated!
This kinda became a mammoth post, sorry for your brains if you had the bravery to read it all
