Potential Coil-Whine?
Hey everybody, I've recently just upgraded to a EVGA GTX 660ti 3gb (excellent GPU), the the installation went perfect, I mean its hard to screw up installing a GPU.. Anyway, when I booted up a game, Skyrim for example, the PSU would make an awfully bizzare sound, I managed to record some of it, but if it is PSU related, would buying a new one (possibly higher wattage?) fix this problem?
Link to video with sound: http://www.youtube.com/watch?v=NLI3f6GE6gA
Cheers
if any psu is making that sound then you should replace it right away. for a 660ti you should need no more than a 550-600 w psu
Is your PSU mounted fan facing down or up? Sound like a grinding noise, or maybe the fan is hitting a wire?
Coil whine isn't generally dangerous - just a difference in frequencies, usually, with desktop PSUs. I can't tell what unit you have from the video, but the coil whine is only in need of replacement if you want to.
i think its your fan, swap it out. if you still hear it its coil wine
Thanks for the quick responses guys, The PSU fan is facing down, so no external cables could be interfering, I am just going to settle with getting a be quiet! L8 730w, it's about time it got an upgrade too..
Coil whine is nothing to worry about unless the sound irritates you. Turn up the music.
