Phenom ll 1055t (locked multiplier)
Stock clock: 2.8 Ghz
Overclock: 4.0 Ghz
Max temp: 55 celcius
Overclock: 4.0 Ghz
That's really good for a bus clock on those old 6 core thubans.
Intel i5 3570k
Overclocked to 4.4 Ghz
Water cooled with Corsair H100i
Idle Temps: 25-29
Full Load : 65
What are your voltages? Been trying to get a feel for how high I can bump up ivy bridge without serious consequences.
Oh hey,
Yeah, Very high. I already have a loud setup but those corsair fans take the cake. My cooler is tasked to capacity.
Luckily I'm the kind of guy that doesnt care about that, and puts on noise canceling headphones.
If you are looking for a quiet setup, you should get a better cooler, or ease up on the clocks and volts. at 4.6Ghz and 1.46v (200x23) I could set the h80i on 'quiet mode', from that point it would be ALOT more quiet than the stock cooler.
Thanks, running RAM at very low speed tho to keep everyting stable 1100 MHz.
I have heard that the memory controller (on the cpu) only can handle 1333 MHz. Might just be rumors :)
http://gyazo.com/33fed8729a16ecb31f200dcb98c3e526 (Old printscreen, managed to lower voltage a little since then).
http://gyazo.com/6fa2773d20e332cb7014033e6cdd68aa (Idle temps are a bit off on these CPUs).
Using a H212@100% fan speed(I can't notice a difference with my desk fan), it has an exhaust directly behind it so it's close to a push+pull config. Also has fresh air fed to it from a top mounted fan use above. Ambient is around 21-22C.
I've done some research into Thuban and they can achieve 1866 MHz speeds but you are limited on the density and how many RAM DIMMs you can use to get that kind of speed.
1.3v is what I've heard is the absolute maximum you should be going on Ivy Bridge without an extreme custom water cooling setup. The heat starts pouring out of the CPU once you pass the 1.3v threashold.
Phenom II x4 955 BE on an MA770T-UD3P
~3.7GHz @ 1.47v, done via multiplier
CPU-NB at 2.4 GHz @ 1.25v
G.SKILL DDR3-1600 at stock rated speeds
Case: Some old CM POS with a meshy looking front and top.
Fans: Three case fans, in @ front over hard drive bay, in at side over GPU, and exhaust at rear top (PSU is on the bottom). All 120mm. Hyper 212 Evo with stock fan on the CPU
62°C @ steady state during Prime 95. Idle in the high 40's.
Shin Etsu thermal paste. So far I think they do a better job making rubber seal lubricant than thermal paste.
Intel Core i5 3570K @ 4.4GHz @ 1.250v
Cooler: CM Hyper 212 Evo
Idle: 30 ~ 35c
Load: 75 ~ 85c
AMD FX-4100 @4.0GHz
Voltage: 1.274500v
Stock HSF
Idle: I don't know
Load: 60c (in extremely hhot room)
"Stable" (no crash, BSOD, prime errors etc.).
Using stock freq. now with higher voltage (1.340500v).
I got 4.3 jiggawatts stable on the AMD Vision utility auto overclocker. I haven't bothered with manual overclock because I'm both lazy, and content with my current clock. Beware: AMD Vision utility sucks at finding errors and can let you run at unstable speeds. I crashed when rendering something in blender with cpu clocked at 4.4 dillamadoos because of this.
Cooler - Enermax ETS-T40 w/ Tuniq thermal glue
Maxed out at 63 degrees in Prime95 tests.
4770k 4.1ghz h100i
idle 30c-40c
load- 75c
a6 5400k at 4.66ghz
30c at idle
45-50c at full load
voltage 1.527v
[email protected] 1.4v Zahlman CNPS14X 120mm 1200rpm Push 120mm Pull 1600rpm
Idlle 28c max 58
This image is after playing bf3 MP 5 hours straight
Last night i didnt closed the window :D
Intel Core i7-3930K overclocked to 4.4 GHz @ 1.225V on Asus RAMPAGE IV Extreme
Thermal paste Noctua NT-H1.
Air cooler Noctua NH-D14 with added 3rd fan. Case fans Noctua NF-P12. Quiet cooling performance.
Temperatures: Idle 36°C / Gaming BF3 max 62°C / LinX 0.6 max 73°C
Prime maxed around 63c
Idle 28~32
Evo 212 Push / Arctic Silver 5
