what mount did you use for the top monitor?
Post your battle stations!
Ohhh nice!
Specs? Looks like KDE with Latte-Dock?
How the f did you get Spotify working on there? Or am I just working on dated knowledge?
Those speakers that are on the floor. Are those 3 way PA speakers?
Do you use them to listen to music while you are sitting at the desk? If so. How do they sound with you listening that close to them
Iām lazy so iām just running Mint with the Cinnamon DE and Docky.
The simplified specs are ; AMD Threadripper 1950X, 32GB of ram and a Sappire Radeon R9 390X Tri-X ( Which i canāt get to run at full performance for some reason ).
And Spotify has actually worked quite well on the Linux distros iāve tried the last 3-4 years actually, so your knowledge is probably dated on that.
I did have some issues getting Spotify to play well with my Asus Xonar Essence STX in the beginning, but that seems to be completely sorted out now.
Wow, the similarities are uncanny.
Cot Dayum, juicy af.
Have you tried the AMD drivers?
Interesting, I will give it another go. The web player sucks most days.
Theyāre a set of JBL LX55Gās i got used for 50 bucks, pretty good if you ignore the fact that the tweeters die constantly.
They donāt sound too bad when iām sitting at the desk, but i mostly use them for background noise since iāve got a better Hi-Fi setup in the livingroom.
But when placed correctly theyāre surprisingly detailed and tight if not a bit harsh because of the titanium dome tweeters.
1 - Yeah, itās a pretty simple setup that just works as long i donāt try to put my HDDās on the dock.
2 - I do run the AMD drivers now, but if i remember correctly the card just refuses to automatically change the power states depending on load. ( Itās been a while since iāve checked though.
3 - Do that, iāve got 3 machines thatās running the same mint configuration where Spotify works like a charm, itās a million times better than the web player or even smartphone player.
Yeah, spotify has Linux builds now. Itās in the RPMFusion and negativo17 repositories for Fedora, I think debian based systems have a PPA for it.
I kicked the web player as soon as support for it was native. (well, itās electron, so ānativeā)
Itās a Lian li A71FB if i remember correctly, itās still one of the best cases iāve ever seen.
EDIT: Iām talking about design here, but cooling is amazing, a maximum of 65C under full load on both a 1950X and a overclocked R9 390X.
So the gpu in the laptop I got burnt out, so I returned it and went back and got a switch instead cause I got fed up with PC gaming, also changed my pi case to a megapi from retroflag
Thatās my old t61p laptop as well that I use just for printing stuff lol
Reorganized my workstation. Canāt remember if I posted my systemās in this thread.
Main PC: Ryzen 7 1700X;32GB RAM;2 250GB SSDs one with Windows 10 and one with ElementaryOS Juno;RX 580 8GB and 2 2TB HDās for DATA and backup.
Secondary: Ryzen 7 1700 Pro;16GB RAM;512GB M.2 960 Pro with Windows 10 Pro.
My two laptops are a Thinkpad X220 and X61.
All my PPC Macs are for giving love to TenFourFox development every once in awhile.
