Figured i should post my temporary setup over here, can’t wait to finish my new setup so i can move everything away from here to restore this place (should explain the holes on the wall).
What i got in this setup:
Monitor: Viewsonic VX2776SMHD (1080p, IPS 27 inches)
Keyboard: IBM Model M (ABNT layout)
Mice: Logitech M570 mk2 and Commatech Iomini 1.1
Speakers: Polk Audio TSi100 (old model)
Mike: Superlux E205U
Headphones: CAL!2 and JVC Ésnsy HA-SR85S (being shipped from the US)
Misc: Phalic cactus, Orico speed mousepad, Orico 10 port USB 3.0 hub and Asus RT-AC1200 in AP mode.
As well as the pièce de résistance, my pristine JDM Onkyo Integra A-817XD integrated amp, fed from the PC via a Creative X-Fi Go! Pro DAC:
The computer in the setup is a little bit kinky as well:
CPU: Intel Xeon X5670 @4.0ghz cooled by a Scythe Fuma
Mobo: Gigabyte GA-X58A-UD7 Extreme
GPU: Asus Strix GTX 1060 6gb
RAM: 2x 8gb 1600mhz DDR3 Corsair Vengeance (without heatsinks)
PSU: Seasonic S12II 620w
Chassis: Cougar Panzer MAX
Storage: 240gb SanDisk SSD Plus G26 + 2x Toshiba P300 2TB 7.2k RPM HDDs
Misc: Orico hot swap HDD caddy and Asus DVD burner.
So I done some cleaning couple of days ago, from left
x230 i7-3520m 12GB RAM 128SSD, my mobile workstation but in home it’s my mostly putty/coding station with 17" Eizo L557 iirc
m2010 an oldie atom and 2GB of 160GB HDD serving as an server for me nowdays
than my main PC, with an NEC ea244WMi and LG 29UM58-P
and at the end my X61T with an samsung screen that I got dirty cheap, I use it mostly for art and some coding.
And to be honest both thinkpads are mostly just locked and I use them via vnc/synergy if I have too do some minor work, and I get them in front of me when I need to do some serious stuff. Also my future plans are to change the screens for I hope another ea244WMi in pivot and changing the m2010 for something more useful for me atm. Probably I will organize some arms for all those monitors to get some extra space, and than I will probably move to another place soo, ye some updates will happen in future.
I took some time to dust my main Pc and to do some planned maintenance, updated the UEFI, added a second fan in the front of the Define R5 and overclocked the 7700K to 4.8 Ghz at 1.260V (no delid yet, evein if I was thinking about it to make it even quieter) and it stays always below 75°C under full load without making a lot of noise, when it’s not under full load it is whisper quiet and that is really important for me, the Fractal case is awesome and the Corsair power supply most of the time, if not always, goes fanless
I did also some cleaning on my dad’s Autocad/SolidWorks Pc, i changed the thermal paste on cpu and gpu and updated the UEFI.
This was my old rig before i gave it to him when his old computer was not usable anymore (and for quite some time i used only my notebook with an external monitor and keyboard)
The cpu is a SandyBridge 2600K, now I overclocked it to 4.5 Ghz at 1.30V and even with the small Noctua NH-U9b it never goes higher than 45°C wich is amazing!
SandyBridge in my opinion has been a game changer, and at the time Intel didn’t use that terrible terrible thermal paste between the die and the heat spreader, you could overclock easily without the whole system being a little thermal reactor
(Again) Still need to clean up my room, but the failed cable management pro wannabe of me from last year is still the biggest horror I have to arrange a rethink of the plan, as I constantly move things around. For example, after my Hackintosh build is now stripped to a barebone for parts to my Linux PC, the cables are now everywhere, since the 800D case is too tall to fit into the designated spot inside the desk.
So, I’m afraid the next picture of my setup is after I get my friend around to help me again with the rearrangement.
That laptop is dead now and has not been used for several years. I tried really hard to get it fixed because it was my 1st computer and cost me £1300 but the gpu would always die after one or two months. I did have a chance to replace the motherboard but it would cost £600 which I thought was too much.
I run Xubuntu 18.04- beta2 on my Dell Precision Tower 3420 SFF Work Station.
My Software Srack
Dell Technologies Vm Ware-Workstation 14.x Pro
Thunder Bird and Alpine (Email Clients)
Web Browsers Water fox , Chrome Firefox
FTP/SFTP and SCP client Filezilla
I find that external cable management is a bear for me to tackle. I generally stuff everything behind the desk where I can’t see it, and hopefully can’t kick it too much.
Which is a terrible solution.
But I still can’t get myself to go wireless and deal with batteries instead.
Cases are going under the desk presumably? Or is this a system swap and simultaneous reinvention of the battlestation?
i will zip tie the cables to the steel bars of the desk , so won’t be visible i think thats why i am painting the zip tie to silver/gray to match so it will be camouflage. as for the pc’s yes will be under the desk , main issue am still not sure i will put only 1 , the other most likely will be temp there just to set up the NAS (have thread about building a nas and asked for recommendation ) but its too big to keep so thinking in very near future after i finish 1 setup and the nas working , i will get a Rak ,very small one then put it on the left side.
i used to play on the haf-x ( black case ) and had the 2nd system at friends house so decided to bring it , so i can game on one and 2nd will be nas + server + Test subject/experiments XD
So I have made some upgrades! Starting with the less awesome: I got a 500GB SSD to replace the Linux drive in my desktop. Then I moved the old 240GB one to my laptop.
The more exciting upgrade is the Kraken 240mm. I was able to up my OC from 3.65 to 3.825. And It also dropped about 5 degrees Celsius. (I think it would be more if this case got decent airflow.)
So the current specs are:
CPU: r7 1700 @3.825
MoBo: Asus b350 prime plus
Cooler: Kraken 240mm
Ram: 16GB
GPU: Reference RX 480
Storage: 240GB SATA SSD, 500GB M.2 SSD, 1TB hdd.
