Post a video on how NOT to apply thermal paste
Post a video on how NOT to apply thermal paste.
Rules are very simple: Just find a video on googletube and post away.
  • First place will be for the video with the most amount of thermal paste applied.
  • Second place will be for the video with the most amount of views.
  • Third place will be for the video with the most amount of dislikes.
Participation ribbons will possibly be given to people who supply photos.....possibly!
Good luck, and let's teach everyone how NOT to apply thermal paste by example.
here is mine after a bit of surfing. there was another video about thermal paste that got a fair amount of dislikes as well.
just watched the video and its a shitty HowToBasic ripoff
Here you go.
massive troll is a massive troll
Using the underrated technique of 'chocolate bar wrapper spread' method created by door-to-door satellite salesmen
Here's a bonus clip from the same video demonstrating the 'press the cpu down directly and firmly with your finger beforehand' method:
Here's one for the international audience with the special 'stroke the processor with your finger before applying' method:
The 'using the entire tube' method
You mean anything that Linus does basically? K :D
This is the most cringe-worthy video I have ever found...just watch it
It's literally everything NOT to do, bundled up in a cute 'I have a screw driver and now I am qualified to take a razor blade to your processor' type of video...
The 'record me while I use my finger' method.
https://youtu.be/alwgXjdQkTY?t=2m
(If you play it from the beginning you can listen to a completely unrelated and non-date specific Christmas carol)
The 'disassemble then reassemble without cleaning and reapplying to take a look at the cpu' method
The 'Face of Wilson the volleyball' method
The 'Let's create art and apply icing to a cake' method
The 'Tap on the cpu several times and pretend it's a coloring book' method
The 'My best interpretation of cuneiform handwriting' method
The 'Let it drip like dog sh*t and spread it with my fingers...then reapply' method
The 'I'm smart, but don't really give a sh*t about cleaning the cpu, touching the cpu, or applying thermal compound correctly' method
Sorry Paul
The 'more money than brains' method
