I'm in two minds about what to do. I'm currently using a 780 to drive two 1440p monitors(pb278q) and I'm looking to upgrade to a Surround setup for 7680*1440.
I'm just not sure what GPUs will be required. I figure I'll need two, but I'm not convinced the 4GB of the SLI 980's will be enough considering I'll be driving substantially more pixels than a 4k display. I'm open to the idea of getting a couple of titan X cards, although I wouldn't be buying them both at once. Probably buying one, get the new monitor and then finally add the second titan.
I feel like I should be waiting for the 980ti, but equally I don't want to wait around for ever. Put it this way - I don't thinking I would be a bad choice by any means to go down the Titan route; but I've never had a reference card before and I'm a bit concerned about the noise.
Any advice?
