This could be a stupid question, but I have but RAM should be running at 1866 MHz. I have 2 4GB sticks of G.SKILL Ripjaws X Series that are rated at 1866. I hope the DRAM in this screen shot doesn't mean that my RAM is only running and 900MHz? http://gyazo.com/dcbfc59241e8a5683fa155413b2879e0
It is running at 1866 - CPUz is reporting the raw RAM speed. You multiply it by 2 to get the effective RAM speed, which would be the 1866 you payed for. You are getting the right speed :)
Ok, thanks! (:
If you want to check RAM frequency i personally prefer Aida as it reports the standard DRAM frequnecy but you can also get alot of additional information about the DRAM modules.
http://www.aida64.com/downloads
Hope this helps. Please enjoy the rest of your day!
Btw, you work for Asus right?
