Hi everyone :)
I've had my current rig (My specs are on my profile) for nearly 5 years, and i'm only recently starting to notice a persistant behaviour that is becoming annoying.
Every so often, i'd hear a buzzing noise coming from inside the case, which has been going on for quite some time now and never caused any actual problem, and normally my computer would be very stable might crash out of the blue, and just recently, last few weeks, i've noticed, my PC has:
(and at the time of me writing this, i recently cleared out my computer case so i know it's not over heating as temps are normal)
Been laggy quite often,
The HDD activity light would be constantly on and programs would be unresponsive for a little while, and then go back to normal, this would happen when browsing(Using Firefox, and constantly check the memory usage in task manager)
also when developing using VS2010, and a few other programs i use.
I've been monitoring what the machine has been doing using AMD Overdrive, RivaTuner, and the Windows Resource Monitor, when the freeze occurs, it looks like the HDD is the most active, according to Resource Monitor.
Rivatuner had shown some odd behaviour earlier today:
The Sensor supply voltage was previously fluctuating in its voltages (some worrying peaks and dips), and this was before my computer froze and both my monitors would be blank (i had to do a Hard Reset because there was no response), no mouse cursor either but the monitors didn't go into sleep mode, nor was there a Blue Screen Crash.
i've looked into several things like for example USN Journal, Virtual memory only to be met with the same behaviour again.
I really hope this is enough information to give someone an idea about whats causing the problem, does that sound like PSU issues or a Hard Drive issue? i'm not completely convinced its the Hard Drive but i can't rule them out as they've aged due to frequent use.
Any Ideas?
Thanks for listening :)
