Possibility of using mSata for caching on Linux
Hi,
I've looked on the web for a guide/some direction on whether it is possible to use an mSata drive for caching on a Dell Vostro 3360 whilst using a Linux o/s (spec. Arch).
I am aware that this functionality was originally intended for Windows, but does anyone know if its possible on a Linux distro?
Thanks in advance.
Caching in what way? As in what type of cache?
If were talking ssd caching for spinning disks /block devices look at bcache or lvm cache http://blog-vpodzime.rhcloud.com/?p=45
I've not set it up myself, but those are the main two supported options.
Thank you for your reply.
Your suggestions appear to answer my question. Now it's time to test.
Thanks.
