So I’ve setup another pve. It hosts a VM of truenas scale and another VM for docker. Truenas SCale has 2 pools. One is a mirrored stripe (14/14, 18/18, 10/10 TB hdds). The other is 2 - 1TB mirrored ssds.
I didn’t want to bother with running docker in scale. I tried it, and it works, but just seemed like I should start off with a separate VM since truenas scale puts me in a crabby mood when I log into the web interface.
Currently all my active stuff is in LXC hosts on a different PVE. It works, I’m just trying something new to me.
Question 1 is this: do you use compose and git, or portainer and gui? From those that use docker, what works for you?
Question 2: do you store your containers on the docker VM’s disk and mount data from truenas, or do you go across the wire (10 gig) and store the containers on a zfs dataset?
