hey guys im looking to put a amd gpu into my 2nd pop os build but two things i want to know for sure 1.
which pop version has the amd gpu drivers pre loaded or do i need to download an if so which ones do i get .
2.i use GWE on my first pop build with my 1660 to control fans an oc an voltage but on a AMD GPU on POP OS
what control software should i use ,somthing like wattman or CoreCtrl ? which should i use
if i can get it while on sale im aiming for the
XFX Speedster SWFT 210 Radeon RX 6600 CORE Gaming Graphics Card.
an a side question can CORECTRL be used to fine tune an control the 3350u apu
in my acer laptop its currently running pop os 21.10 with the xanmod 5.16 custom kernel
the instructions at the bottom of this page to enable voltage/clock control if it doesn’t work by default: Setup · Wiki · CoreCtrl / CoreCtrl · GitLab
? the section under
Full AMD GPU controls
has instructions for a grub loader but under my pop 21.10 on my acer aspire 3350u far as i can tell thers not an i havent installed a grub loader do these instrutions still apply or would they not work on this laptop being that i dont think or i dont know if the cpu is unlocked
an if so any advice on best voltage an clock setting to go for
preferible it like to set the max boost clock to 2.5ghz as it seems the most stable at speed an not so damn hot
the reason i say 2.5 eventho under load the acer aspire 3350u will peak at 3ghz the heat produced during the duration use combind with anything im doing make to whole laptop to get very warm an lockup even go down
but any task that at load peaks only around 2.4 - 2.7ghz doesnt an i dont notice any performence diff in use
between a peak of 3ghz an 2.4 to 2.7ghz other then the stated issues
so if with corectrl i could lockin or taper to the fq speed of 2.5ghz id like to do that would this be doable
