Hello, everyone!
I wanted to post this here since this is the place I got the guides for half of the thing I am trying to do. Hopefully I can get some help in understanding if this is the Pop_os installer shitting itself of me being incompetent. So I wanted to set up my system in Raid 0 mode and do a root partition encryption using luks. I used the mdadm utility to setup Raid 0 and then cryptsetup to encrypt the created partition.
I was following 2 guides from this forum by Wendell, can’t include links so I will just include the ends:
how-to-install-ubuntu-20-04-to-linux-me-raid/154105
gkh-threadripper-3970x-setup-notes/156330
Thanks a lot to Wendell for making those!
Separately either raid 0 or full disk encryption- work. I can either have my whole system(minus /boot /efi partitions) on the raid 0 array or have my system installed on one drive with full disk encryption but as soon as try to do both I get the “could not install” error. I have the screenshots and the /tmp/installer.log but for some reason can’t link it, maybe because this is my first post, not sure, maybe I will be able to do it as a comment afterwards? Am I doing something wrong or its the installer messing up?
for now last few lines from the installer:
[ERROR distinst:ffi/src/lib.rs:48] libdistinst: pointer in FFI is null
[INFO distinst:crates/disks/src/config/disks.rs:447] decrypting partition at “/dev/md0p5”
[ERROR distinst:ffi/src/disk.rs:677] decryption error: LUKS partition at ‘"/dev/md0p5"’ was not found
[INFO distinst:ffi/src/lvm.rs:55] getting logical device named ‘pop_os’
