So I have been on Pop_OS! 20.04 for about a month and so far almost everything is going smoothly since it is my third attempt to ditch Windows for good.
However, there are some minor issues I would like to resolve. Firstly, after suspend or a longer session, the desktop environment starts to lag a bit as if it was to drop a frame or something. It is especially noticeable in videos (Youtube) and games. I can fix it with restart but that is not the most convenient way. I have no idea whether it is a Pop_OS! issue or GNOME and I have tried to turn off extensions (I am only using the default ones) - but without success. I found something similar on reddit, with no solution.
The second problem is only cosmetic. Pop shop keeps showing me that I have an update (screenshot included) although there is none when I search for it. In the same way - apt update and upgrade show no new packages. Is there a way I could get rid of that notification?
Thanks for any help
