Following my initial thread on improving cooling in my old computer, I decided to make some improvements.
Realizing that the 120mm Fan was performing much better the stock cooler provided by AMD, the initial test I had simply zip tied the fan just above the stock heat-sink to see temp differences (as shown below)
However to improve this setup I decided to remove the fan and the stock heat-sink and build a DIY fan with the knowledge that the cooling would improve, Here is a summary of the process:\
I found a 92mm heat-sink in my box of spare parts, this would be the new one I used to replace the stock AMD heatsink. I removed the 120mm fan from its kinda rough zip tied arrangement and started from scratch to build a CPU Cooler. See parts below:
width="720" height="480">I got the zip ties and carefully started to wire together the 120mm fan to the 92mm heatsink, this task required a lot of patience and about 30minutes of time.
Installing the new DIY CPU Cooler was a bit of a mission the initial issue I had was that the clip which locked the heat-sink onto the motherboard was wobbly and would not fit tight, so I ended up having to remove the CPU Cooler again and found another clip which I had to re-attach to and then placed it on the motherboard. After a few adjustments it was a good fit.
Temps improved significantly.
width="720" height="540">
I hope this DIY guide to CPU Cooling and building your own air cooler was helpful.
