So im just sitting here playing some wither 3 while listening to some 90's hits, whatever no big deal when you're PCing it up.
But it hit me me poor consolers those mother Fu..... cant multi task in their OS. I mean for me it's an everyday task to alt+tap between my tasks, be it gaming, youtube, programming, what ever. Hell had development VMs running while playing wither 3 and taking a break.
If you wanna make a change to the world then introduce a consoler to multi tasking, besides the obvious hardware which is worse than pc laptops.
Show them you can watch netflix on your TV, while gaming on a monitor. Show them you can have facebook open, while browsing ebay, and no special apps needed todo so.
I've always maintained that a PC is a better value proposition than a console because it can do tasks other than gaming and you'd have a much better experience than say an older desktop/laptop as well as a PS4/XBOX, even if you are only doing menial tasks the extra performance does help even if the hardware was bought primarily for gaming.
Also from your initial point, you are able to listen to music on the PlayStation 4 using the usb music player which is compatible with FAT32 usb storage devices.
