I sleep in a King, and I wouldn’t want any smaller due to the space the person I’m sharing it with manages to take, even though she’s only 160cm(5’3").
I sleep on water, much more comfortable
You have your own place? Most apartments ban water beds.
Yeah, it’s unfortunate, yet understandable, that most apartments are against the idea lol
What graphics does your main system have?
- Radeon
- Geforce
- Other(Specify)
0 voters
No ability to choose both, or Intel? (integrated atm… until Raja’s project comes to fruition?.)
I guess ppl with only iGPU’s wouldn’t bother voting?
Vega 8
AKA just enough to play old games at low settings.
firepro M5950 here
Id go wit h vega 56 or 64 if it wasnt so damn expensive, got an ultrawide 1440p freesync monitor and I cant use the freesync because the cheapest option to run that resolution was a 1070 :cries:
I mean, it’s not cheap but it is down from where it was like two weeks ago:
seems canada went down by $100
Workstation grade gpu in a workstation laptop
Still $100 over launch MSRP
Isn’t that from the ATI era?
Amd era
It’s an AIB card though, not reference. Nvidia is the company that sells those at a premium, AMD the other way 'round (good or bad notwithstanding).
I should say generally as there are certainly super-premium versions too.
Do you wear shoes inside your house?
- Yes
- No
0 voters
Do you (personally) need more than 4 cores on a weekly basis?
- Yes
- No
0 voters
Please specify if yes.
