Basically a thread to ask for / point people in the right direction of special hardware.
No walls of text, just quick and to the point.
Is there a fanless SFX PSU? I know semi-fanless ones but haven’t seen one actually without a fan.
Doesn’t have to be powerful, full load of the system is less than 150W.
Silverstone has something coming out Soon™ that might work. I’m not sure what the difference between SFX and SFX-L are, but here’s the link I found anyways:
Have you thought about buying an overkill PSU that has a fanless operation mode? I’ve got a full-size PSU that operates fanless up to 400w if I remember correctly.
Indeed, latest update is from June.
SFX-L might be a problem since length is exactly what my case can’t handle.
I have a 300W Silverstone semifanless that might be fine, was just curious.
What about getting an extra long first half of the cable for the brick, assuming it is laptop style with replaceable wall plug end. Then just stuff the pico brick in where the PSU would go anyway? Maybe not elegant but could be dressed up.
I feel.like I am missing something though, very obvious. Never dealt with small supplies.
I am no stranger to jerry rigging stuff but in this case I would go a different route if I have to. Those external bricks are not for me, if I mod something I would start with a known brand like my silverstone SFX and go from there. I am thinking about removing the case of the PSU so the heat can radiate out of it on it’s own. It is rated for 300W and the fan is pretty quiet, doesn’t move tons of air. So a system running less than half on full load shouldn’t be a problem.
I appreciate you guys trying to help but I wanted this thread to be more of a binary thing.
“Does THIS exist?”
“No. (Because reason)” / “Yes, here is a link (google this)”
As far as I can see the answer to my specific question, passive SFX PSU, is no (sort of).
So, thanks everyone and feel free to PM me if you do find one.
I am looking for a super small case for a somewhat powerful ITX build. I already have one in mind but hey, this place exists, right?
I am aware of the Dan case and I think there were a few other kickstarter cases like that. I don’t want to wait and I want the thing to be done, in stock and ready to purchase for a not stupid price.
This is kind of the list of stuff that is probably gonna go into the build:
ASRock X470 Gaming-ITX / ac
AMD Ryzen 7 2700
Noctua NH-L9a-AM4
G.Skill Trident Z 2x8GB 4000MHz CL18
Sapphire Radeon RX 570 Pulse ITX 4GB
Samsung 960 EVO M.2 in 500GB or 1TB
SilverStone SST-ST45SF-G 450W 80+ gold SFX
Board and CPU are almost set in stone, I already have the memory, cooler, PSU and GPU.
(I am looking at R9 Nano auctions though)
So in short:
ITX formfactor for board and GPU, SFX PSU, low profile cooler and no SATA anything.
What case comes to mind?
EDIT: First recommendation is no longer available, apparently.
If you can find a Lian case, they’re awesome. And if that’s your thing. A buddy of mine has a baby blue one that he had given me for a while. When he came back, I gave it back to him. I have cats, so it wasn’t viable
Ah, in stock. I thought they’d gotten to that point by now but apparently not.
Edit: honestly it bugs the shit out of me that the neatest cases are just made on preorder runs. Like the Ncase M1. Super popular, but they can’t be bothered to make 1000 at a time and sell them all. Because they will all sell.
I dont know if you can get this at a reasonable price but your stuff should fit in the Rosewill RS-MI-01 BK no problem and its pretty small. Its far from the best case for its size but it should be cheap.
