Fairly simple question, but I have a command that works when running as a privileged podman container, but now I’m trying to run them in a build and its failing and I can’t figure out why.
What works:
podman run --privileged quay.io/reavessm/reavesos:catalyst catalyst -s latest
What doesn’t work:
podman run quay.io/reavessm/reavesos:catalyst catalyst -s latest
nor
FROM quay.io/reavessm/reavesos:catalyst
#COPY portage/ portage/
#COPY specs/ specs/
RUN catalyst -s latest
#RUN catalyst -pf specs/stage1.spec
Can anybody help trouble shoot this? I can provide more information if needed
Is this the AMD proprietary driver? If not what is catalyst?
If the userid used by the software in the container does not match your userid, then creating temporary files/directories will likely fail. You should be able to figure out the userid used in the container by looking at the original Dockerfile.
So its calling rsync and rsync is failing to write to a directory that doesn’t exist. I was able to create the directory and the rsync succeeded but now its failing somewhere else.
Is there no better way to troubleshoot this besides hopping back and forth like this?
A quick glance at the gentoo wiki implies catalyst does most things in /var. You could create a volume and mount it to /var.
podman volume create catalyst-var then use the volume option to make the volume available to the container podman-run(1) — Podman documentation Then the container should be able to write to the volume.
I am seeing that the python script is failing calling an ‘unshare’ method which says its a simple binding to the ‘unshare’ linux syscall. I’m guessing that’s the culprit but I’m not sure.
