Aeign
January 22, 2014, 4:24pm
1
I was wondering what are you guys' thoughts on PNY's GPUs and if this particular model is worth buying.
I looks so appealing because there is a discount on it that brings it 40€ below the next least expensive GTX770.
I was going to buy a GTX 760 so now i can't decide due to it costing only 10€ more.
http://www.bit-tech.net/hardware/graphics/2013/09/27/pny-770-oc-review/1
looks like it uses good components and the 7+1 phase should be good for overclocking.
Aeign
January 22, 2014, 4:36pm
3
I've seen that review xD
The problem is that that is PNY's double fan version of it and that's the only version i've seen reviewed. The one i linked is the triple fan version and there are no written reviews of it.
the specs look the same so the cooler is the only thing different and i would have to think 3 fans is better than 2 so it's even better at cooling
hmm i notice that the one you listed has a lower memory overclock.
Go for it. I have had good luck with them in the past.
Aeign
January 22, 2014, 6:50pm
7
Thanks, That's all i wanted to know :)
