I want to use a Center for Internet Security (CIS) Win10 Benchmark VM ISO, for my workstaions OS. Is the feasible? If not, please elaborate as to why. Thank you.
What, exactly, is your setup here? Is there any reason you cannot run Windows directly? Why this particular ISO and why not Windows 10 Professional, for instance?
Yes, this would probably run, but I don’t see why you would want to.
Great question. I have a Windows factory USB and want to install it on my VMware environment, as well as primary OS.
Ok, then the only way to be sure is to try it.
