I'm building a new pc and was wondering if this is a good computer for programming gaming and blender.
Specs:
Case: Corsair 250d
Motherboard: MSI Computer Corp. Z87I AC Motherboards
Cpu: Intel i5 4570
Gpu:Evga gtx 760 sc
ram: kingston hyperx fury (color black)
psu corsiar cx600m
cpu cooler: Noctua NH-L9I
Case fans corsair af120mm quiet edition.
hdd: Wd blu 1tb
is the noctua going to fit on the mobo with ram installed and is the psu enough?
sorry for bad english i'm spanish
Very nice itx build mate. The cooler will fit without a problem. & the PSU is way more than enough - you could get away with less.
It will be a very capable rig to suit your coding & gaming needs.
how many watts do you recommend for the build though? 500 550??
The CX600M will power that just fine.
Jody
May 17, 2014, 2:19am
#6
Minimum is 600. So, in other words, get more. Tom's hardware says to get a 750-850w PSU. I got the 750 because I cooked one that was 650 watts with this card in there.
but can i get less oi would prefer it since i can save more money
I have an i5 and a HD 7950. The 7950 has a higher power consumption than a GTX 760. I'm running it off a high quality 550w power supply just fine.
(My build): http://pcpartpicker.com/p/2iyxk
The CX600M is pretty inexpensive right now. I would just recommend that you stick with it.
well i put the parts on cooler masters calculator and it said 430 watts was fine and the other guy said 600 was enough.
