Please review BenQ RL2460HT
can tek syndicate please review this monitor for its low blue light feature?
i have the predecessor to that monitor (the RL2455HM). great monitor. didn't know it had a low blue light feature. guess it causes less fatigue?
it has a better stand (height and tilt adjust) and has an HDMI out for use with a capture device (as oppossed to having the capture device output to the monitor, which can cause lag.) but other than that, i believe it is the same panel as my RL2455HM.
i go to Displaylag to check input lag for monitors. it is a great site, and i am highly susceptible to input lag.
it should be a great monitor, as it just seems to be an RL2455HM with better stand, HDMI out, and low blue light. And my monitor is GREAT. input lag is indistinguishable from CRT. they even had Justin Wong (one of the best fighting game players) help to design it. and Street Fighter has a lot of 1frame links, so you know it is a fast monitor.
in the review, there is a video on the low blue light tech. hope this helps :)
http://www.displaylag.com/benq-rl2460ht-review-gaming-monitor-hdmi-output/
thanks for the link it helps.
no problem :) glad i could help.
