Hi everyone!
I wold really apreciate it if someone helped me with my build because im having a hard time chosing the specs.
Wich combo wold give me the best performance for the money? ( try to keep it as low as possible)
Motherboard:Gigabyte GA-990FX
RAM:G-skill ripjaws 8Gb
Heatsinck:Xigmatek dark knight
HDD:western digital caviar blue
PSU:corsair TX 600W
Case:cooler master storm enforser
all of these parts are about 500 dollars
Now which of these combos will give me the best performance for the lowest price?
FX-8350 and the Radeon HD 7850:380 dollars
FX-6300 and the Radeon HD 7850:320 dollars
Phenom || x4 and the Radeon HD 7850:280 dollars
Phenom || x4 and the Radeon HD 7870:350 dollars
The budget is 700-around 800 dollars MAX!You cold change something in the components!
What FPS will i lose if i go lower and lower from the most expencive choice!
I will be gaming only! Its very hard so im sorry for that and try to keep it as cheap as posible?
Very BIG thanks to all!
I'd probably go ahead and get the Phenom II X4 and a Radeon HD 7870 XT. It's an amazing bang for your buck, and since a greater majority of games only care about your clock speed and that you have up to four cores, it won't really matter for gaming which CPU you get. Some people will try and sway you for a FX 6300 for the bare minimum, but it still isn't really necessary, as it would only give you 3-7 frames in-game boost. But the significantly more powerful graphics card will more than make up for that. And the board you chose is very good for overclocking, so the Phenom II should perform very well.
Try fx6300 and 7870, imo 8350 is not needed until 7950 up, where it really makes a difference.
Also on newegg http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1245908
Check out the 8320, my friend has a gigabyte 7870 in a build i put together for him. I used the 6300.
If you only care about gaming, id go for 6300 and 7870 if you are on a budget, your build though.
Most importantly what games do you play the most?
Phenom x4 is amazing, i will agree, but my it isnt as future proof. Mndless, I have used both, and the 6300 is better imo for games like bf3, but if he plays only gpu intensive games the x4 will be fine. Im just saying, games like bf3 and likely 4 are using a lot of cpu power, to the extent it makes a big difference on mp
Well when i get the PC i will play Far Cry 3.I F**king love that game and well other games like batman arkham city crysis games like that.
Ok so i wont get the FX-8350 decidint on geting the FX-6300 rather than the Phenom because its more future proof combined with the 7870 BUT can you guys lower the price on the other components if its possible!Wold really apreciate that too ^^
I understand that the Phenom II X4 doesn't perform as well as the FX 6300 in Battlefield 3, but if the difference in price means the difference between the Radeon HD 7850 and the 7870 XT, then I would cut my losses and get the better graphics card, because for most games, you will notice the better graphics card far more than the better CPU. The Phenom II X4 is sufficient for most games, and it doesn't cost a terribly huge amount of money, so if you wanted to upgrade later it wouldn't be as huge of a loss. If you can find a combo deal with the FX 6300, then by all means buy it. (Do note, the 7870 XT is not the same as the regular 7870 and it is not the GHz edition either. It is based on the Tahiti LE platform and has 300 more stream processors and more texture, raster and unified shader units than the standard 7870. At about the same price as the higher end 7870s.)
The 7870xt is out of stock at newegg and is $250, you might as well get a $270 7950
If you like the cm handle cases, http://www.cmstore-usa.com/scout-atx-mid-tower-gaming-case-refurbished/
Its $40 refurbished, imo refurbished cases dont matter like other parts, and they are just as good
You are correct about the CPU i will see if i can get the FX rather than the Phenom but in time ill see.
Now about the GPU im considering getting the Radeon HD 7870 HIS BECAUSE Logan highly recommended it and the 7870XT is better but it is 260$ rather than a normal 7870 which now is 220 so i cant get the XT versoin.
heres the review:http://www.youtube.com/watch?v=UkOZhwutP-o
No dont look at the case.If something happens and my budget drops ill simply get a NZXT source 210 or the Bitfenix Shinobi.But if you guys cold lower the price on the other components wold be the best!
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182131
Corsair, seasonic, silverstone, enrmax, and other high high end psu are overpriced imo, check out antec and rosewill, pc power and cooling, also thermaltake DO NOT get a diablotec or logysis cheap psu, it can fry your whole system if it goes bad.
The tek syndicate 6300/7870 is the build i would recomend the most
Yes im very awer of the PSUs capabilities.Logan always refuses to go cheap for the PSU :D
It really can burn down you house :D but the choiceu gave me is the best for the price
The hive one I sent, Its really good, rosewill have been making really good products for the most part lately.
http://teksyndicate.com/forum/build-pc/alittle-help-please/136923 ^^
you can also edit youre topics and titles, if you put it central to one topic, then it maybe will a bit better to follow for youre self ☺
its just an offtopic tip ;)
grtz Angel
Guys,i REALLY apreciate the help that you gave me!Ive been so woried about all that CPU/GPU noncence.I mean really Thanks so much! :)
I saw that, i think he revised his build though
