Hello all! This is my first post in this community, so I hope it's well received :)
Well, I just graduated college and am looking to build a new PC (one- just for the fun/experience, two- to have a nicely running desktop).
After having consulted several videos/reading a bunch of people's stuff, this is what I currently have (using the layout suggested by the forum):
Budget:
Goal:
I am looking to build a good gaming rig that runs almost anything at full throttle (will also be used for personal use here and there) - so... I guess 40-50+ FPS?
Also, I've never OC'ed, but would like to learn/get into it (hence the cooler in my parts list)
I am going for a black/red-ish color scheme if that helps at all.
Monitor/Peripherals:
Currently planning on a single (24-27") monitor and possibly adding one more in the future (was thinking ASUS VG248QE)
Do need new peripherals, but haven't had much luck with ones fitting my build color scheme that was to my liking. If you have any suggestions, please do!
Also, still trying to decide between Win 7 Pro and Win 8.1 (currently using 7, but thinking to try the new OS).
Lastly, here is a list of parts that I am currently thinking of using, which is mainly what I would like feedback on:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core
Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler
MB: MSI Z97-GAMING 5 ATX LGA1150 Motherboard
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory
Storage: 1) Samsung 840 EVO 120GB 2.5" Solid State Drive 2) Western Digital Caviar Blue 1TB
GPU: Sapphire Radeon R9 290 4GB Tri-X Video Card
Case: DIYPC Adventurer-9601R (Black) ATX Full Tower Case
PSU: Corsair 760W 80+ Platinum Certified Fully-Modular ATX Power Supply (I know this is overkill for this current build, but I'm thinking to add/switch the GPU in the future?)
For pricing, here is the PartPicker url: http://pcpartpicker.com/p/K2MPQ7
Thanks for reading and for your help!
