I built my first pc, i put in all of the components without a graphics card (still being shipped) and it worked just fine, i just installed my graphics card and it won't turn on, i can even see the bios flashback light on my motherboard but the rest of the pc won't turn on
you realize that unless you jump correct pins your psu will do nothing. take it to a pc repair shop besides anything really big like bestbuy (because geek squad is a scam) that gives free quotes and they will most likely help you
i don't want to do that. i don't want to waste my money on that unless i truly have to. and also because want to learn how to fix issues like this incase of future problems.
i don't think its the graphics card. i do it with out the graphics card and still nothing, the fans don't even turn on. the only this that is on is the green light on the motherboard when i ply in the power supply cable
i checked mine. its not that. the really weird thing is that i put my build together last week without the graphics card. and it ran smoothly, fans and all. and then i put my graphics card in today and it doesn't want to do anything
