(sorry for my bad grammer and spelling I'm 14 years old and from Netherland and I am dislecties , so yhee)
http://pcpartpicker.com/user/blackwolf/saved/2Tbf this here ar the parts dat i wil buy
So my build has a budget from €600-700 (that is arond $700-800).
I'm ready to buy all the part's but I don't feel safe whith the motherbord. It is a Asus M5A97 R2.0 ATX AM3+
Please if you see some thing that I can do better whith this build than let me know.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231416
its great ram and a great deal but not sure if newegg ships where you live..
thanks I feel a bit save now :)
I can buy it somewhere else, Thanks :)
might want to look into a CPU cooler especially if overclocking...
I just bought a Enermax ETS-T40-TA: http://www.newegg.com/Product/Product.aspx?Item=N82E16835214024&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
Coolermaster Hyper 212 Evo is also highly recommended if you want air-cooling
or the coolermaster hyper 212 plus which is cheaper than the evo
Thank you Guy's for the tips
