Please Help! Looking for a new way to charge my laptop battery!
Okay so basically a little while ago I broke the female part of my laptop where the charging cable goes. So, I was wondering if there was another way to charge my laptop. For example a docking station, like how you would charge an Xbox controller, a USB form of a charger, or a portable charger like you would use on your cell phone. Sorry if the grammars bad, my writing skilllzzzzz aren’t very good. Thank you for your help, I really do appreciate it
Which model is your laptop? a dock may be your best bet.
Its a dell inspiron
Seems to be several on ebay, see if you can find one for your exact model and your all set.
Thank you, I really appreciate it
