FX-4300 Build; http://pcpartpicker.com/p/30bX6
Athlon Build; http://pcpartpicker.com/p/30cbV
Are these good? Should I change anything? If you can cut the cost do it! Could this run skyrim?
For me, i would take the athlon, also the GPU on the 4300, is pretty terrible. I would get something like this http://pcpartpicker.com/part/sapphire-video-card-112011720g
http://pcpartpicker.com/p/30cIH Heres another build to tickle your fancy. Or you could even try for a 750 ti on sale, or a AMD 265 when it comes out for a little bit more change.
How about this Sapphire Radeon R7 260X 2GB GDDR5 HDMI/DVI-I/DP OC Version PCI-Express Graphics Card 11222-06-20G? And could this build run sky rim?
http://pcpartpicker.com/p/30gXo here is almost the exact same build,, but using the 260x, and yes it will run skyrim at max http://www.tomshardware.com/reviews/radeon-r9-280x-r9-270x-r7-260x,3635-13.html
The GPU I posted is a 260x
yep, either will work fine.
Sweet :D
Thanks for your help :D
